BAMF Forever 1.10 FINAL is out
Just flashed and I must agree with everyone else. There is a HUGE difference! No more being frustrated with the lag for me.
I don't understand why mine wont. I don't think its related to the rom. Some people have this problem regardless of rom. I haven't got a clue how to fix it. I tried updating youtube and flashplayer but it didn't help. Wont play in explorer either yet all my other streaming media from hbo etc do work.
Have you tried uninstalling then reinstalling YouTube? If that doesn't work maybe uninstalling updates or erasing app data could do the trick
Yes I have tried those things. Youtube won't even work if I use it in the internet
Works fine in 3g
Now it works again this morning. No idea y
When I receive calls, 80% of the time I cannot answer the phone because it does not give me that option. Does anybody know of a fix for this bug?
or flash 1.11.. havent had the end call bug once since flashing that. imos lean 5.1 kernel.
For those using the 3++ Kernel, what are the ideal settings? Not talking speed but the governor and i/o?
I am on smarta$$ noop.
I'm having problems with my WiFi and network connection lately. When I'm on WiFi, it seems when my phone is idle, it reverts back to being connected to the network. It just started doing this. Any ideas?
Recommend: Don't use ROM Manager for anything except flashing Recovery!!!
I only use ROM Manager to backup my ROM. I use to use it to flash, but I boot into recovery and then go from there...I factory reset (when needed) and wipe cache and then install from CWM instead.
anybody recall how to change the locks? have the ring lock and want to switch to the slide bar lock.
or am i confused with another rom?
My WiFi does this too. I just stopped using it all together.
5GController
