Battery help?
Very decent battery life imo , It looks like there was a wakelock for about 1 hour duration , have you identified the source ?
I think you will give much better battery life if you can fix that wakelock.That would bring awesome 4h screen time.
I get around 4 hours screen-on time and 8-9 hours standby with brightness above 75% throughout sometimes 100% all the time (No task killers , No battery saver apps , No Anti-virus)
What is a wavelock? Haven't heard that term before
Sent from Galaxy S4 using Tapatalk
A wakelock keeps an Android device awake in order to perform a task. There are full wakelocks and partial ones. Full wakelocks typically keep the screen on (like, for example, if you're watching a video), while partial wakelocks will awaken the device without activating the screen in order to perform a task (like Facebook checking for new posts or messages).
I see..I don't think I have anything that does that on its own that I know of other than something that I caused the screen to activate
Lots of apps and system processes execute wakelocks--they're generally normal, but with some apps, they can get out of hand. Apps like Wake lock Detector can show you what's keeping the device awake, but it doesn't work on KitKat, I think.
How come they don't work on kitkat ? is there any specific reason like API's ?
Not sure--all I know is that these types of apps stopped working for KitKat.
baby boy
