I was having problems with battery life when I first installed too but I was able to fix that by doing the following:
Charge the battery to full.
Turn the phone off while still plugged in.
Unplug and restart the phone into CWM.
Go to advanced and wipe battery status.
Reboot and do not plug your phone into USB or any other source of power until the phone dies from low battery. You want the battery to the point that the phone will not even boot.
Now charge the phone over night.
I highly recommend trying this method. I have a significant improvement in battery life now.
I will give this a try...but I'm not very optimistic...I'm down 20% in an hour. That's right...TWENTY percent. Ridiculous.
And I have actually done a wipe, gone all the way back to DI01, and a fresh reinstall.
Something about froyo and my phone isn't playing nice!
I'd say we need a widget list, what apps you use a lot, and what's in your battery usage under settings> about phone. Do you use a task killer? Are your wifi bluetooth and gps on all the time? Dl30 or eb01?
I can't seem to get to the advance area in cwm to reset the battery. When I hit the home key on the update.zip tab it just gives me a screen with the triangle and the droid on it. Am I missing something?
Yep. there is a problem with your updae.zip file. Welcome back by the way Jmac. Refresh my memory. Which method did you use to get to EB01?
DroidXcon version SuperClean from above thread.
Yep.
Gotcha. So people who were previously rooted are the only ones running into this problem. People who never rooted and are coming from stock don't run into this hiccup.
yeah mostly , so if you flashed via odin and put that file on your SD card there is no reason it shouldnt go directly into clockwork
