that is still putting update.zip in a sub folder. when you plug your phone into your computer with the usb cable, do you get an auto play window that pops up?
EDIT - I mean when you plug your phone in with debugging on and then mount the sd card
5 Hours 67%? Im down to 40% within 2 hours.
Yes. The card is mounted and debuggin on. The auto-play menu pops up. I hit "no action" and then open the F disk. Is that wrong?
Do that again, but when the auto play opens up, click on open folder to view files. This first directory that opens up is the root of your sd card and that is where you need to put update.zip. You should see folders in that directory like clockwork, system, etc. Once you put update.zip there you will be good to go.
EDIT - Sorry, or you could have opened the F:disk and ende up in the same place. Either way that is the root of your sd card
Take "update.zip" and make sure it is sitting at the very top level of the SD card. My directory header says "mnt/sdcard/" That fixed the issue I was having, which sounds the same as yours.
Finally got it! Thanks for sticking with it Landshark (this crosssed two different threads and lasted about three days for me....what a relief!). Yeah the F disk was opening to the same place and I had put it there before but it worked this time so I won't question the cyber Gods as to why it didn't work before. Again, many thanks!!!
I flashed EB01 earlier this week and have been getting AWFUL battery life ever since. I flashed SC2.4 this morning hoping that would help but it's not much better.
It's funny because on DL30 I had great battery life, now it's horrible. Going to try flashing back to DJ09 then up to DL30 to see if that helps.
I guess I have some good vibes coming my way...
I have already charged from ~40% to 100%, turned the phone off then continued to 100%. Currently running battery down to dead with Pandora streaming, full brightness, 10 min backlight, GPS, WIFI, BT, etc. Going to charge back to 100% overnight.
If that didn't work, I was already planning on flashing back to DI01 and then back to EB01 SC2.4. I will keep you guys posted on what happens. Thanks!!!
Chewy, try this method. It worked for me and for others:
Charge your phone to 100%, power off and keep it charging til it hits 100% again, turn it back on, charge back to 100%.
Hi Shark,
When you say "turn it back on, charge back to 100%" does this mean;
use it until it is at 5% and charge it back up or
just turn it back on, it might read 98% and charge it back up to 100% again?
The second. then when it reaches 100%, unplug it, go into recovery and wipe battery stats, reboot phone, let it drain to 5%, then charge to 100%
It took flashing JT's EB01 voodoo kernel buy my standby time is finally acceptable now and not dropping like a rock when it's sitting still.
