battery usage is horrible - how to optimize
Yeah then go to motion smoothness in same menu turn to 60hz
Ok so I have FHD+ set
I can not set motion smoothness to standard (60hz) because battery saving is on.
I had to turn that off.
What else should I do to save battery?
I have dynamic lock screen off
Yeah battery save automatically puts it in 60hz , turn AOD off of tap to see in settings>lock screen
Dark mode and turn 5g off you should see significant difference
Great. I will try those and see how it goes
I really appreciate all the help. There is always a learning curve with a new phone plus this is the first time I used android 12
Thanks
Thanks
Welcome
Yeah I agree new phone /new Android version new things to learn
Yep 5G seems to be one of the worst things to come along for the consumer since non removable batteries :eek:
Turned off on my pixel and wife's Samsung. Even when you know you are in 5g coverage the battery drain is surprising.
I very much agree on both counts. I really liked my first smart phone with removable batteries. I kept a spare on charge and swapped them quickly and easily anytime I needed
As you can see in my screenshot it says LTE and now this screenshot shows LTE without WiFi Screenshot_20220821_095225.jpg
Actually I think it is strange on my phone. I think it is showing the 5G with the LTE behind it. Part of the E sticks out on the right
Charlotte Breece
