Now you are just making things up Droid800. You obviously did NOT go beyond looking at the homescreen and a few apps.
Your comments clearly show you have not seen or used the display. If you did use it you didn't look beyond the homescreen or you simply weren't paying attention. I don't just make things up. That would be pretty ridiculous.
At any rate, even if they do use it it doesn't mean its a bad thing. Some people wont even care. Its a deal breaker for some and others could care less. That's usually the way these things are.
Sent from my Droid
Wow, a huge assumption on your part CK. Just because you are bothered by the look of a pentile display doesn't mean everyone is.
Yes, if you grossly over magnify the screen you will see the grid pattern of the pixels and pentile looks very different than RGB stripe. This is not inherently worse, just different.
If one does any research on pentile you would find that there is a lot of imaging science involved behind the scenes. What most people state regarding 1/3 less subpixels is a gross oversimplification of the technology.
Will I like pentile? I have no idea yet, but to state unequivocally that, since you see issues with it, everybody should is a bit egocentric.
