Bricked my phone while trying to Flash
...This is the only thing i miss about not having a sd card. I flashed my og evo time and time again, got stuck with faulty roms, downloaded alternate ones, loaded them on the sd and re flashed to safety.
If you could only get into recovery to check for a nandroid backup...or if you could access your files while connected than you could load another rom to flash...
Sorry i skimmed the threads but at this point do you know what recovery you have? Twerp or CM?
They are all factory unlocked as far as global use. Is he insinuating that it is the developer edition, aka, it was s-off, and bootloader unlocked from the factory?
Jennifer Stough
Forums Moderator
Device: Droid DNA unlocked, s-off, rooted, running Hatka Supreme Sense 5.0, Android 4.1.2
That's what I gather. I can't get a hold of the moron though. Think he's avoiding me on purpose
Is there a way I can reflash my phone now that I'm on the HTC Screen? I can't get to the bootloader though.
CM!
Did you power off or did it finish the flash?
Jennifer Stough
Forums Moderator
So right now when you try and boot you're stuck on the boot screen. What about when you try to boot into recovery? How far do you get?
Jennifer Stough
Forums Moderator
No the flash didn't complete. It was still stuck on 30% and then I did the adb reboot bootloader. I can't get into the bootloader now though.
Hm, can you get back into recovery?
Jennifer Stough
Forums Moderator
I can't boot into recovery. It goes directly into HTC One splash screen. I tried holding downt he volume button. No dice! :(
Need help big time! Running out of cards in my deck
Hmm Even if you didn't load your rom (that you were trying to) correctly you should still be able to boot into recovery.
When holding down power and volume down do you continue to do so all the way thru the boot attempt? When i boot into recovery i hold power and volume down all the way from off thru the load up and htc one screen. My first time it took several times to get into the bootloader because i didnt hold long enough
Getting into the bootloader was kind of tricky to begin with on his phone, not sure why, but I suspect it had something to do with fastboot
Jennifer Stough
Forums Moderator
Jennifer Stough
Forums Moderator
Well that's not helping things
Try to turn the phone off by holding the power for about 30 second, and then boot it up again holding both power and vol down at the same time. Make sure to keep the phone in bright light source or it won't turn on sometime. Let me know if this let you boot into the bootloader.
Someone asked me to do that on XDA forums, and I tried that, didnt' work. No other help from xda forums though :(
I put it under my bright lamp
What does the adb reboot bootloader command give you?
Jennifer Stough
Forums Moderator
Any more advice? I'm stuck
Well recovery is where all the magic happens so as of now i'm stuck. Thats the first thing that needs to be figured out how to access recovery. I dont think you're dead in the water yet but it might not be figured tonight. Sorry for your current predicament.
Jennifer Stough
Forums Moderator
Was hunting through threads on xda forums, found somethin that pointed me to this:
All-in-One Toolkit for the HTC One – xda-developers
via : [Q] I bricked my HTC one - xda-developers
You think I should give it a go?
Jennifer Stough
Forums Moderator
Nothing, phone just restarts.
I have a quick question. Would the bootloader show up if the bootloader was NOT unlocked?
I ask this becasue as a last resort I'm gonna try going to HTC
probang
