Bricked my phone while trying to Flash
Downloading the AIO kit right now. Anything I need to know/do before using it? Dont want to make any mistakes :(
What does the adb reboot bootloader command give you?
Jennifer Stough
Forums Moderator
Device: Droid DNA unlocked, s-off, rooted, running Hatka Supreme Sense 5.0, Android 4.1.2
SUCCESS!!! Got it open uo CWM-Based recovery! Oh dear god this feels good. Thank god for Hansoons toolkit!!
I'm back on the CWM-Based recovery. What should I do now guys?
SS below
Yeah I had something similar when I flashed something that wasn't compatible with the ROM. Once I reflashed recovery I was good. Glad you got it working.
SS below
You can either check the backup/restore area for some safe earlier versions to get you stable or attempt to install from SD.
SD? This device doesnt have an SD though.
I'm really nervous as to how to proceed. Don't want to be makign mistakes lol
Okay I get what you mean now. I just checked and Android Revolution HD is still on there. SHould I risk installing it again? What if it gets stuck :O
If it gets stuck it's an installer issue, not ARHD. While you can still reboot into recovery clear your cache and go ahead and install.
What I'm worried about is being able to get back to recovery mode IF it gets stuck in the installer again....Cause I have no idea how I really fixed that issue and got to the HTC splash screen where it got stuck again
So what steps should I take that I probably didnt take before?
I'm really glad to hear that you got back into recovery.
Jennifer Stough
Forums Moderator
Jennifer Stough
Forums Moderator
You think I should try ARHD again?
How do I go to Nandroid or wtv you guys were talking about.
When I select "Backup and Restore" I have the following options:
-backup
-restore
-delete
-advancded restore
-free unused backup data
-choose default backup format
-backup to internal sdcard
restore from internal sdcard
-advanced restro from internal sd card
-delete from sd card
I guess none of these pertain to me since I never made a backup... sigh ...just realized this after typing all of that out
I was worried too but I just went ahead and reflashed and was fine. Just go man.
Thing is, unlike you, I havent REFLASHED recovery yet. All I did was use the "Boot into Recovery" option under the "Commands" list in the AIO
Should I flash recovery and THEN install the rom?
Thanks again man
By reflash recovery, do you mean using adb and fastboot to flash it?
Jennifer Stough
Forums Moderator
No, you don't need adb if you're using the AIO.
Aio...I'm out of my league here, lol. Po, I tried my best. Hopefully you can get this up and running! I'm glad you've found help, don't feel bad, it took a whole weekend to get my phone rooted, unlocked, and s-off as well as flashing a Rom. I was terrified. But after the first go you get a hang of it. If you ever need anything else, don't hesitate to ask, I will do my best to help as much as I can.
Jennifer Stough
Forums Moderator
Jennifer Stough
Forums Moderator
Well I thought I helped too, then he said he didn't do any of that so I have no idea. Bedtime.
Jennifer Stough
Forums Moderator
AIO is the tool I posted above! It's an All In One tool that I found
Here are my options now, using the Hasoon2000 AIO
1) Re-flash a recovery - ClockWorkMod, ClockworkMod Touch, TWRP AND THEN Install zip via sd card
2) Do above ^^ but install via sideload
3) Just erase cache with AIO and install zip from sim card
Not sure which one to go about doing...
Now that you got back into recovery, I would just restore your last backup and maybe redownload the ROM you're trying to flash it pick a new ROM.
Sent from my HOX+ loaded with Elegancia ROM v5.2.0
BrüZZi
