Cleaning up your device data/storage
jyoung
Active member
May 17, 2010
40
9
Now that we have all had this device and loaded, unloaded, reloaded.....apps and data, etc. Are there any good "house cleaning" tips anyone has for keeping the X running smooth and efficient.
What tips and tricks have you tried successfully?
power off the phone
hold the home key while pressing and holding the power button
when you see an orange triangle with an adroid press the search key
use the volume rocker to scroll down to wipe cache
use the menu key to choose ok
is this the same as a system reset or will all my installed apps and settings remain unchanged? Also will i lose root?
Aliraza
