Cold As Ice working on Optimus V!
Just flashed Alpha 15f with the VM fix earlier today. Runs great. No more clock lag, decent battery life, seems as fast as CM7. Great work Kraven.
anxious to try this rom out. currently running backside IHO CM7.
i've been reading around here and android forums a bit, is there still an issue with MMS or is that old news?
Check out the GO sms fix earlier in this thread.
yaay, found it, thanks! already have go sms, so i'm familiar with it.
I have no MMS issues, I am running the latest CAI alpha16 with VM 16 fix plus I am using cannibal for CWM recovery. I do a full wipe three times before I install the ROM (leslieann file).
Yup
after reading around a lot last night i decided to try out quattrimus first. so far i'm pretty stoked on it, one weird thing though... if i reboot the phone while i'm plugged onto a power source, it turns off and gives me the battery charge icon instead of doing an actual reboot. i'm sure i'll eventually play around with CAI as well.
its supposed to do that... its offline charging
Yes. But JerryScript had it setup better I think. I'll need to look into his changes.
would it be the same for ICS as gingerbread? he didnt push any ICS changes to git before he fell off of the face of the earth..
birdsong2000
