Got my new Note 2! Got it connected to my PC (Windows 7 Pro x64) via USB and synced up Outlook Contacts, Tasks, Calendar. Great.
Excited about getting work done on the go with my Note 2, tried to set up WiFi connectivity with my laptop and the Note 2. Figured out that I have to use Kies via WiFi in the Settings menu, and also run the Kies application on my PC at the same time. Kinda painful - if only I could have the beauty and simplicity of old Nokia phones with Nokia PCSuite!
The Note 2 was simply not finding the PC on the same WiFi router. After much web searching and learning about numerous frustrated Kies users due to connectivity problems, guessed that the issue must be with my Symantec Endpoint Manager. Disabled it, and it worked! Device found the PC and connected successfully.
I have now created a firewall rule to allow all traffic between my PC and the MAC address of the Note 2. Initially enabled traffic only for the Kies processes/applications, but that didn't work. Had to enable traffic for all applications.
Hope this helps someone else struggling with this.
First step - temporarily disable the firewall software on your PC and see if you are able to connect. Then figure out how to set up a firewall rule to only allow the device (identified by its MAC address) to get through. Strangely, I had to be connected to my company VPN in order to be able to set up the firewall rule - otherwise SEP does not allow Network Threat Protection settings to be changed.
Finally synced via WiFi, but very disappointed with the sync results - duplicate tasks, and many issues. Subject on another post!
