CyanogenMod ROM
Do you want CM6 for the LG Optimus S?
  • Total voters
  • Poll closed .
Got ClockworkMod working correctly this time. Flashed ThundeROM 1.5 w/o issue after renaming the it to update.zip
Will do. Might not be able to till I get back to work on Monday but asap!
Congrats on get it. Just so you know tho you don't have to switch recoverys. GB works on the amon recovery.;)
Cool,so you got your recovery all fixed up and flashing? Do you still have to rename to update.zip?
Yep flashes fine. I flashed the deluxe build prop without renaming it.
Oh by the way, I got one step closer to AOSP running. Now the LG screen flashes on and off, which is closer to working than just freezing on the LG screen :)
Were you able to pull a log?
He'll get it, I think he is just passing the wrong param. mkbootimg is a pain and even my script gave me trouble for a while. it wants everything just right lol.
I gave him my script so hopefully he'll get as far or further than I got. I had CM6 running a while ago with no support for anything except the touch screen and 3d (copied from 2.2 stock). I had no FM Radio, no BT, no Phone, no sound, no wifi... lol
Good luck :)
Good luck :)
Yeah it is,ive had problems with it several times.lol
sweet! :)
Did patches merge correctly?
The patches merged correctly, and AOSP runs on our phone. The only problem is I got it booting using the boot.img from nRom, so it lacked the drivers necessary for AOSP to run well. It's one step further though, since we know that the ROM I've compiled works fine.
NW1
