[DAS] Bamf 1.6.3 - Ads Block does not work after re-enabling it?
anon(220176)
223
Per the thread title, there is a feature in this ROM under DAS Bamf Toolkit to block ads. It works well but sometime I had to disable it to access some site, such as FatWallet web referrer.
Unfortunately, when I disabled it and RE-ENABLE IT, none of the ads is blocked anymore, from website to applications. I have tried rebooting the phone, pull out battery, etc. but to no avail.
Do I have to do Clean Dalvik Cache and Application Cache or something?
I would try clearing dalvik cache and rebooting.
Don't think you need to clear application cache, unless you mean your browser app, in which case it wouldn't hurt to try it if wiping the dalvik alone doesnt do the trick.
Antoine-Henry
