data usage/battery with data on
Scholfield03
Active member
Jan 30, 2013
38
Hey all, getting my pixel 2 in the next couple days. Was just wondering how the pixel 2 is in regards to the amount of data it uses and also how long the phone lasts with data network always left on. I know that some phone are heavier on data usage than others, for example I've heard that iPhones tend to use more data in general than others so was wondering how the pixel is
The Pixel uses as much data as you want it to. If you want to restrict data for certain apps, you can do that. If you're on a quality mobile network, be aware that some apps like Facebook, YouTube, etc will see that you have a good connection so (for example) YouTube will serve you up super high quality video so that's going to use more data. This isn't anything to do with the phone.
I have never turned off my data on any Android phone that I've used. I use WiFi at work and home. I get a full day easy with my 2016 Pixel XL. I'm not always on it, playing heavy battery sucking games, but the data connection does not drain the battery at all.
Unless you're on a very small (< 500MB) data plan, you'll be fine. Even then, you can set your data limit in the settings to warn you then shut off your data so you don't get robbed by your carrier. I think you'll love your Pixel 2.
No phone should really use more data. Such as when you stream the same song at the same quality it should be the same size regardless of iPhone or Android. That part really depends on you and what you allow mobile data to use.
KidColoringPage
