ARCHIVED: [DEAD ROM] LEGO-ROM-v2
Status
Not open for further replies.
Quick noob question, is launcher pro compatible with this rom? And, are all apps in the market compatible with this rom?
Yes, they are. I have launcher pro and all my previous apps work just fine when switching to LegoROM
Just curious - any updates to the pattern lock issues with this ROM? I know it was being worked on, but I haven't seen anything in awhile on it (unless I missed it)?
Yes there is an update coming, it does require you to be on VC baseband. The compatible themes for it will fix the pattern lock bug.
All themes should be compatible with the update :) The bug was within framework.jar and the themes don't touch those files :D Definitely some luck involved there on my part.
So whats the future of VC since Sprint is pulling the update. Will all new ROM updates still support only VC I assume, making V9 almost useless to those of us who like to flash current versions. If so I assume that the update through LG still works?
Sprint is not pulling VC.
First, thanks so much for the hard work you guys are doing. This rom is really makes owning this phone that much more enjoyable.
I'm curious about the browser force close bug that was talked about about a month ago. It's the bug that force closes the browser when you hit the stop button (next to the url bar) while a page is loading.
It looks like it was talked about for several pages, along with talk about a fix coming, on January 31st (that's where the posts that came up on my search were put up on). However, I could never find a place that said, "here is the fix", or "it's been fixed in the current release. It also looks like it hasn't come up for quite some time as well.
I'm having the browser force close problem still, and what I'm wondering is: has this indeed been fixed and I'm doing something wrong? Or is the fix still coming? If it is still coming, or never came, that's obviously ok... I just want to make sure I'm not missing out on the fix if it exists.
i miss my lego rom... *sniffles* its like a friend died.. :'( But Beezy said it would come back so..... :D can't wait *stares at the screen w/ anticipation*
This has been the most user-friendly, well written guide I've come across. Many thanks to everyone involved, I love it.
Status
alejandro109322
