ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
I need to activate my Optimus S. I've downgraded from CM7 to stock 'MVC' to do so but it's stuck on the 'Hands Free Activation' pop-up. It says, "Contacting network..." and never goes anywhere. Is there something more I should have done besides wiping data, cache and reflashing? Oh, btw I did restore a nandroid backup rather than reflash a stock rom. Could that be the issue? I've been messing with this all night and can't get anywhere. Even Sprint didn't know why it wasn't activating.
Please help, desperate!
What is your baseband version? The baseband (radio) needs to match the ROM version. So if you are on VC you need a VC baseband or provisioning wont work.
If it still wont work, just call sprint and tell them and they will give you the MSL and guide you through programming it manually. Be on stock rom when calling, the secret codes don't work on CM7.
I'm in Dallas Texas and I know that the Sprint stores around here are real good about replacing screens on their devices free of charge. You might want to check into it. A real good friend of mine has had his EVO screen replaced 2 times since he got it in Feb.
Seriously??????? dernit!... there is ONE Sprint store in Winston-Salem and I've been in multiple times to get either my Bro's Rumor2 fixed or my Palm Pixi fixed. and they said they would not replace a screen free of charge. Your screen broke? too bad, pay full price for a new one or discount price for a used one. only things covered were defects.
Yeah dont use a nandroid. Use kp500 to go back to vc or v9, v9 is better because its easier to root IMO, then try getting connected to the network.
HFA works 3/5 times but that still leaves a huge error margin. My replacement lotus (which did come today despite UPS saying it wouldnt til tomorrow) just failed HFA and I had to manually program it. I always copy the MSL from the activation page to my google doc anyway >.>
Need it to disable the hideous OneUI in dumbphones.
Wow, getting forced closes when hitting the search button in facebook app and its not syncing right, I am going to reinstall see if that fixes it...anyone else have this happening? Seems like my 3G data was not working right either...Im gonna reinstall...
Glitchsta
I think it is usable enough currently, the small bugs that are left over are the cost of getting gingerbread on something that hasn't even been slated for an update, despite rumors of the Optimus One line being updated.
Someone will get bored enough and grab the reigns. I'm holding on to my Optimus, until the Nexus S releases, but who knows, someone might get a gift if they make a couple promises.
I know the S doesn't have the bleeding edge processor in it, but it has other things that make it attractive to a developer. Plus it's the most easily un-lockable device short of the nook Color.
your right ovum pigeon. I luv rhat I am runnin cm7 and nuck7 can NEVER toucj cayanogen on dev status.
Ok I just installed the latest build and the build 0411 from wiped system and facebook did not work with search and updating, I installed the build from 0404 and facebook works, I am now gonna try flashing the newest build over this one without wiping and see if facebook works...and facebook works, weird if I do a clean install it will not....
Anybody having any MMS issues since the 4/19 release i did a full wipe and debugged ziped it then flashed? I tried freezing in TB and unfreeze but still no worked. Rebooted and wiped cache and dalvik again after flashing but again no go.
Mine seems to work fine as well.
One word of warning though, had been switching a lot of stuff over to Google voice recently (though not through Sprint's official message) so test MMS messages sent from my phone to my google voice number did not work (message would show as sent, but I wouldn't even get an email notification that the message had been recieved... though text only messages worked fine). When I get some time set aside will do some testing from another phone, but might be a Google centric issue.
I really like this rom and to the person above, my google voice works flawlessly, you probably arent setting it up correctly.
My only complaint is it says Bluetooth is fixed and maybe so in regards to connecting devices but when I use my Bluetooth headset sometimes it will not even transmit the audio and the worst part is there is so much static you cant hear anything anyone says. Does anyone know if they are working on this or a fix for it? I get the same issue on both versions of CM7 on this board. I currently am running the ThundeROM and it works flawlessly with my headset and I have also used CM7 on an HD2 with my headset and worked perfectly. I know it isnt my headset, it is the rom itself.
Another thing is the GAPPS needs to be updated because most of the time when you flash the GAPPS you dont even get the market or anything.
Thanks.
I don't really use Google voice but I do receive a lot of multimedia for my business and it worked before I updated last night. Probably just gonna go back to 0411 update.
Thanks.
EVERY time i've flashed GAPPS, market has been the first thing to pop up, being as you kinda need it to download the rest...
idk, might be your phone or a bad dl.... can always dl again?
Status
athegn
