ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
Battery life's been fine for me as well. Phone has been running hotter, but then again it's gone from being 20 degrees outside to being almost 80, so I think that might have to do with the 30 degree increase I'm seeing in temperature.
Ahh bad link??
yep. zefie's getting some much needed rest, as should i (i've also been up for a couple days, but for exams, not developing :D ) anyway, if you don't have 15 yet just change the '16' in the bad url to a '15' to get that version. 16 will be out shortly, be patient..
Optimus V? I don't have one. You are welcome to fork the source code. I'm sure there isn't that much to be done :)
Only swapped 'menu and home' keys and MMS. Other than that, nothing needs to be changed.
CM7 on the Optimus S/V, the best phone for the money spent, awesome! You guys ROCK! :D
in my case, zero money spent (got it on sale for free from sprint). i take that back, actually.. a donation is definitely in order.
thanks! i havent had any version yet.. was waiting for the support to at least be to what it says now..
Just flashed version 15 a couple hours ago - everything is working great minus most of which has been mentioned. I do have 1 bug I don't think was mentioned. It only happened once so far, not sure if I should report it to the bug tracking page yet.
Had my phone plugged in to charge at work with usb, let it sit and charge for i dont know, at least 1-2 hours, maybe more. Turn screen on to check something and there's no backlight. Screen comes on but it's as if it's at 0 brightness. I already know about the bug where you can't adjust the brightness.
EDIT: just restarted the phone, backlight is back. Also noticed the battery is now full. Wondering if reading full battery might have had anything to do with the backlight. Wouldnt know - not a developer and have a limited understanding with that.
wow! i haven't come in in a few days and already a lot of stuff is already fixed!
so everything seems to be solved besides usb? anything else having problems right now?
edit:oops sorry didn't notice the log on pg 1
man, thanks zefie and testers for all the work
Auto-sync doesn't seem to be working for me (no Gmail notifications). Anyone else experiencing this?
Hows this rom running? JW looking to flash this on her phone as im running cm7 on my evo and its hott!
Sent from my PC36100 using Tapatalk
Status
shadango
