theone1000
- Apr 26, 2011
- 3
- 0
- 0
Just use Type Fresh. I'm using Akzidenz Grotesk as we speak![]()
Thanks for the suggestion but I keep getting bootloop with TypeFresh. Decided to use RootExplorer instead and worked perfect
Probably. Give it a try. Little things that change between networks like mms (picture mail) may not work....will this work for the optimus v
Try reflashing. If that doesn't work, just wait for an update to this. One should be out soon. They are still trying to get it to package properly with no errors before releasing it. btw, it may show EV at the top. If that is the case, it's still 3GI flashed it and it works great BUT lol now i have no 3G any help on getting my 3G to work again??
Thanks,
why off?
Ok everyone, so since Zefie's repo was having some errors in the vendor tree when compiling (prevented compiling at all), I had this idea: The aospCMod ROM for the Optimus V works fine on our phones when the correct APN's are added. This means that the vendor tree for the Optimus V will work fine with the Optimus S. Therefore, I can take nightly source for CyanogenMod, start a new repo, and use the Optimus V vendor tree, and then add in the Sprint changes. I'll try and keep it exactly like Scott Pilgrim Awesomeness (minus the bootscreen... I like the stock bootscreen better).
Does anyone know if zefie stopped supporting this ROM completely?
he broke his phone and something about a computer i think?
