I did the same and it also worked for me.
Thanks I'm up and running!!!
Is anyone else having placing phone calls? I place a phone call and hear nothing. Is there anything that I can do to fix the issue?
Thanks
right now i have the thunderom installed...and im kinda new to android and the whole modding thing...having this custom thunderom how do i go from this to CM7 Gingerbread, im not sure what the proccess is..
I felt the same way when I first started this adventure. Just follow the steps on the first page exactly and you should be OK.
Ok I did a clean wipe and reflashed build 20. The sounds been fix and i thank u for that. However GPS still seems alittle broken, meaning I still can't use weather & toggle widget or the weather channel app to use my location for weather. My Navigation also still can't locate me
If anyone knows wats goin on here plz let me kbow
I flashed over from the nightly form the 16th tot he 20th today and my battery chewed through to nothing in no time ( like 5 hours). no difference in use ( basically I did not make any calls or use the data). anyone else notice anything in this build?
thanks, can i just place the new rom over this or do i have to go back to stock? also how is this rom...im hearing its the best one out
just put this on my phone and i am not connecting to 3G, it is only giving me 1x. I updated my Radio to VC before applying CM7 to my phone. i followed the directions and wiped out user data and cache data before applying, i have also re cleared the cache, but it is still only giving me 1x. any advice?
Thanks
This rom runs great for me! I used to run ThunderRom 1.6.2 and I dont know if I will ever go back, even though 1.7 is built with the VC files? I just have a few questions about this rom if anyone is kind enough to answer them I'd appreciate it =] Is this rom built with the new VC update files? Is there any need to flash with the build props? I saw JIT is enabled but is stagefright or HW accelleration? I am trying to get away from using a launcher as I was using ADW Launcher but the only thing I get from it is I could set swipe up on the screen launches settings, is there anyway I can set a swipe gesture with this mod? I really love it guys keep up the good work...I need to get a donation to ya'll....thanks alot guys...would appreciate any tips - Glitchsta
