The DragonTJH
- Jan 13, 2011
- 148
- 10
- 0
Is there a way to get the Visual Voicemail feature back from the original Sprint build? I kind of liked it...
I will submit this as a bug as fast as I can, but when I am in a call and volume down it mutes the incoming audio until I volume up one Time, is anyone else seeing this issue?
I did a clean wipe on all flashes builds 16 to 20 except 17. Everything works great expect the GPS, as in my weather channel crashes when finding my location, my weather & toggle widget can't find my location and neither can my Navigation. GPS works just ok because it doesn't update my location as much as stock did or thunderom. One more thing I don't know if its revelent or not, I don't see the satellite icon since I started using cm7 when using GPS to find my location. Hope that means something to someone and can find a solution
Sorry if this has already been asked (I couldn't seem to find it in this thread) but does voice command work with CM7? When I push the button on the side of my phone that used to control it, nothing happens. I've also installed swype beta and when I click on the microphone icon, nothing happens. Thanks!
Thank you. Now I know what you are thinking - how did someone root their phone and install CM7 and not know the answer to a question like that? Your guess is as good as mine.Go to the market, download and install Voice Search. It was preinstalled on your phone from Sprint. It is not preinstalled on CM7.
One last question (while I have the floor): now that I have installed this, it works with Swype. However, the button on the side of the phone that used to activate Voice Search is still not doing anything. Do you have any idea how to get that to open Voice Search (or any other program for that matter)? Thank you.
does this really work for cm7 has anyone tried this for the optimus phones
how do i format my memory card just delete everything off of it from my computer or is there a special thing or something i do in recovery....or something
