RamboDroid
A|C Fanboy
- Dec 16, 2009
- 167
- 24
- 0
Now I'm just looking for a simple way to get a battery percentage in the statusbar.
Not sure if you've seen this already, but if you go to Settings>CyanogenMod Settings>Interface>Status Bar Tweaks there is a checkbox for battery percentage. This runs fine on the themes that come with the rom. Hope this helps.
I dont havd that option in my cyan settings. odd.
There is a problem with the proximity sensor which may have something to do with this. Its low tech but swipe your finger across the sprint logo and then to the left. The sensor is just to the left of the sprint logo. You can see it if the light is right. Hope this helps.
Sent from my Gingerbreaded NookColor using Tapatalk...
I can confirm this. It seems the proximity sensor needs to be uncovered, covered, then uncovered again for the screen to come back on during calls.
Same problem
I had to restore the market from titanium.
The 'wireless tether for root users' app works, even if the stock app/hotspot widget doesn't.Has anyone had success with getting wi-fi hot spot feature working?
I don't seem to have that option.......... where can I get 225?
Flash this via recovery. Don't ask questions just do it.
No but it's just a silly boot animation I put together for this Scott Pilgrim Awesomness.
What does it look like
Get it on the first page of this thread. Zefie has a bit of a typo, it says:
"Test Build 02202011:
Download Test Build 02252011"
See, he didn't update the "Test build" title, but he updated the link. Short version...just click the download link in Post 1.
