ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
The colors on the status bar determine if your phone is synced or not. Colored wifi / bars means you are synced.
Reactions: zefie
Bluetooth Audio not working
This ROM is fantastic. I am running V9, i rooted and updated straight to the 0220 nightly. GPS works fine on maps and navigation.
Only issue I am having is Bluetooth Audio does not work for phone calls (I haven't tested for music).
I assume this is the same issue that is identified with audio?
I flashed to 0225 and am still experiencing the problem.
Any ideas if this is fixable?
I experienced the same. Bluetooth works great with music not phone calls. Love this ROM.
I already have a dropbox otherwise I would have signed up as well through zefie's link. Dropbox is great for storage. You may want to try zumodrive also.
Zefie: Thank you so much for all your hard work and dedication in making the Optimus S a best-in-class device. Without members like you in the Optimus S forum, we wouldn't be able to truly enjoy and unlock the potential of this device. Thanks a million.
I never had an issue with the Sprint apps since using CM7, but the way I did it I think many people overlook. Many of you may not like it, but I backed them up with Titanium Backup before flashing CM7. Then I restored them with Titanium. Except, the only Sprint apps I have/use are Sprint TV and Telenav, can't say that works for the others. Also, I installed those apps in Data, not system - as in when Sprint ID asked me to pick 1 way back on the first boot, I chose the Sprint theme to get their apps, removed the ones I didn't want, and went from there.
Recap/instructions:
1. Make a nand backup
2. Go back to a normal Sprint ROM with Sprint ID installed (anything but CM7)
3. Install the Sprint ID pack, remove the apps you don't want
4. Download/install Titanium Backup
5. Make a backup of your apps
6. Restore your nand
7. Re-install Titanium Backup
8. Restore the Sprint apps you want from Titanium Backup
Worked for me, but again, I want to point out these are just things I've done since I've been messing with this phone - not all at once.
Is anyone else having an issue with incoming calls? On my wife's Optimus S, she will occassionally not be able to answer incoming calls (no option to) even though the phone is ringing...and the phone keeps ringing until we reset it. Loving the rom otherwise...but that's driving her crazy and getting me in trouble! Lol.
occasionally my screen wont "wake" to allow me t answer or hang up on calls.
Recap/instructions:
Where can I find a stock rom at?
Recap/instructions:
or just download the pack here: http://forum.androidcentral.com/lg-optimus-s/61554-i-need-sprint-aps-cant-find-post.html
and extract and remove the apps you want.
There is a problem with the proximity sensor which may have something to do with this. Its low tech but swipe your finger across the sprint logo and then to the left. The sensor is just to the left of the sprint logo. You can see it if the light is right. Hope this helps.
Sent from my Gingerbreaded NookColor using Tapatalk...
I looked in the blacklist settings...and my number and her mom's were on there... I don't know how that happened (she swears she didn't do it on purpose! :D) Anyway, I flashed the most recent version and cleared her blacklist and the problem hasn't reoccurred.
anyone else having issues with market force closing? I cannot get it to open, it just force closes. using the GAPPS in the first post
Status
Ellieeeeee
