ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
I already have a dropbox account, is there any way to link it up even thugh i've had it for a month or so?
No, don't worry about it though. So far I have gotten about 6 referals, which is about 1.5gb. I'll take the link down when I reach the max, but right now I have enough space for some more NIGHTLYs :)
Thx to all who signed up :)
I signed up as well, Thanks for this great Rom, I'm a few days old in the Android world lol. Thanks for all the hard work, I cant never stop playing with my phone now lol.
Yay and your welcome! Its been awesome to be able to keep up with my friends that have nexus one and galaxy s phones running cm7. Thanks for your hard work
Help! Having an issue with losing my screen after making a call(unusable. blacked out. have to pull bat.....) then tried to restored to before cm7 and now have lost that! Tells me to go through adb. Had to flash back to t-rom 1.6.2. Anyone else have this issue.
not updated...thunder recovery....used the debug zip
Signed up and downloaded the new nightly.
Found a cause to an earlier problem I had with my theme. I forgot to flash gapps and thought that the new release had fixed my issue. When I did flash it my problems came back. My data and signal strength icons only match the theme when in a call. My question is how would gapps affect this?
what? I noticed starting on a clean boot my icons are white then eventually change to the color of the theme. dunno why or what causes it. right now they are blue and its idle (cyanbread theme)
i dont think its gapps as much as it is the reboot you are performing to install gapps. :P
The white text is your normal call and sms service. your themed color means you have 3g data. I often get data lock on my v and use airplane mode to trouble shoot this. Test it out, trust me :)
If my text is white I cannot use data.
Sent from my LGE-VM670 using Tapatalk
I'm using rovers theme ...there was a link somewhere back about page 10 maybe....try it out. Right now those icons are basically cyanbread stock but they should be a circle that's white. If I turn on airplane mode they go into the theme for a couple secs then revert to cyanbread. I'm gonna rehash the nightly without the gapps again and duplicate it.
hey zefie, you just missed out on the annual dropbox giveaway that happened recently (december maybe?). it was basically a clue hunt that offered up a total of a gig of space. so now i've got 3 gigs of space instead of the standard 2...
Reflashed and the theme worked properly again. Rebooted and still worked right. Flashed gapps and gave out a chance to mess up at each step in the setup and the theme didn't change to the wrong icons until I actually signed into my gmail account...wierd....
Status
Bry
