ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
Huh, I never noticed the change in post 1 before updating to 302. I just wiped cache, dalvik, and /system as per usual. Did not wipe data....and it still works fine. Of course, if I run into issues I'll do the wipe before I complain here :-D.
so how do we flash this exactly when we don't want to just update to a newer nightly build but switch to this ROM from something elas?
1. wipe data, cach, and dalvik like you would with any other rom
2. format sd card and move the debug, Gapps and the build.zip to it
3. flash the debug.zip
4. flash the Gapps.zip
5. then finally flash the nightly build itself?
1 flash debug
2 flash rom
3 flash gapps
really that it:)? cuz i read the notes part in the first post and it said to reformate the memory card or is that notes part just for if it doesn't work doing it the first way that was just posted
Make sure you wipe /data and /cache on your first time or new OS updates! :)
Reactions: uberjam545
ok let me make sure i got this straight flashing this is pretty much the same as any other ROM except after you wipe data, cache, and dalivik you have to flash some extra stuff (the debug, the nightly and then the Gapps)? and you dont have to go through the trouble of reformating your sd card?
Yes thats exactly right...just put what you need on the sd card...reboot to recovery. Wipe data, wipe cache, wipe dalvik...now without rebooting go to flash zips and go:
1. debug
2. rom
3. gapps
All back to back...finally reboot out of recovery...
k thx for your guys help if you cant tell im always very careful about not messing up my phone.
alright i got it up and running thanks again to everyone that helped me earlier today, and to zefie for being an android ninja and making this possible
Happy birthday zefie! This is my first post and I'm only doing it to show my respect to all the hard work you do for all of us less knowledgeable folk and hope you're enjoying your b-day!
Reactions: zefie
I just put CM7 on my phone Zefie I love it keep up the good work. Now onto my question I use handcent sms messageing program for my sms messing and wanted to know if there is a way to disable the sms messanger app that comes with the phone?
Thanks
mgardner323
Thanks
mgardner323
Open the Messaging app then press menu and select settings. Make sure "Notifications" is unchecked. This keeps from the double notification.
Hey zefie, any chance of 03032011 nightly? I'm experiencing excessive battery drain on 03022011.
Have you tried acromack's thread http://forum.androidcentral.com/lg-optimus-s-rooting-roms-hacks/64258-tweak-improve-battery-life-cm7-scott-pilgrim-awesomeness.html.
I used it on 02252011 nightly and worked like a charm. 7hrs 53mins and was at 92%. Granted it wasn't heavy usage but it was better than before acromak's suggestion. I have since flashed 03022011 but have not had it off of the charger long enough to see if works the same.
Just curious, what is your CPU set at to give you those kinds of numbers?
Status
jmarshallcleaning
