Hey so i havent been using the nightly for the last two updates and heres why:
When i downloaded somethin from the market, it wouldn't download and it failed or something. Is this fixed?
I was runnin VD by the way
Flashed the latest build without wiping and it works great, only problem I have is the gmail app does not automatically refresh I have to do it myself, does anyone know how to, fix that thanks
Sent from my rooted LG Optimus S running CM7
It used to work for me, maybe 2 builds ago, maybe i need to wipe all and start fresh
Zefie I think I figures it out you go to settings then accounts click on your gmail email address tgen check thr box next to gmail, for some reason it was not checked to sync with gmail app it is now and I should be good to go...you gotta start using this rom it is so badass!
ah, yep. Reason its not checked on its own, is because when you sign in to your google account, gmail isn't installed yet.
derp. perhaps since we are not going official I can change that in the next nightly![]()
just wondering why you took performance cpu setting off that was my favorite one.
thx this has to be the smoothest fastest version yet thx alot
Performance is pretty bad at sucking battery life. It keeps the CPU at max clock speed the entire time, never scaling it down. It's akin to putting a brick on the accelerator pedal of your car and just shifting into neutral when you come to a stop light.
so what are your setting. i am using interactive min320 and max 768
