ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
Is anyone seeing battery improvements? 10 hours with wifi on has me at 45% with some good usages.
That's close to what I got before I flashed this. Last version I was getting 10 hours and still over 50% for the most part. I'll have to see how this fares tomorrow since I just flashed tonight..
Wiped everything and flashed formatsystem.zip. Flashed latest CM7 and gapps, restored everything no problem. Then I noticed that my clock time was about 6 hours off. Checked settings and made sure it was set to "network time" so I did a reboot. Got stuck with Scott Pilgrim rockin out. I waited at least 5 minutes and then pulled the battery. Powered back on and got the same results.
Anyone else have this happen?
Maybe had something to do with restoring from Titanium Backup????
Gonna reflash tomorrow and see what happens.
I think it has to do with restoring settings. When you reflash, restore only data and apps. Then try again.
Reactions: jstntp
second, i was already doing really good with 317
Interesting. I don't think I was doing this good previously. So far I'm at a little over 14 hours cell standby, 11 hours wifi running, phone idle is 10 hours, display is 4 hours and calls is about half an hour. So I'd say a good 3-4 hours of use (forums, news and browser) and I'm now at 20%.
Usually I'm on the charger by this time.
Maybe its just me. Will find out in the next few days.
My battery life also seems much longer. I charge my phone every night regardless whether it needs it. Normally I'm at 20-30%. Last night I was still at 65%!
After just one day to compare, but, I'd say yesterday was the most battery life I've had since owning the phone.
Reason being is part of the hack to enable wifi tether also always forces wifi power management to be on too.
Update PRL
Any way to update prl with this or not needed
There is no Sprint Provisioning built into CM7, so you will need to use a Sprint based Rom to update your PRL, then restore back...
1)Nand backup of current CM7
2)Flash ThundeROM, nROM, or LEGO (whichever is compatible with the baseband you curently have on your phone), or even restore a nand backup of one of these Sprint based ROM's.
3)Update PRL
4)Restore Nand backup of CM7, that you made in step 1.
This all assumes that you are currently on CM7.
Reactions: dbeckwit
03272011 broke L2CAP bluetooth support on my phone, was working great on 03172011, went back to 0317 and now can't get it to work either
The only thing youve been able to do with Bluetooth is transfer files. Please read the last two pages of posts there has already been talk of what does and does not work in this rom. Bluetooth is listed as not working.
OMG the prox sensor is working!!! it's the most amazing thing ever!! thank you so much for your heard work Zefie!!!
Bluetooth works with audio also just not phonecalls. In my experience anyway...
Ok SO I reinstalled 03172011 and it took a couple seconds but bluetooth worked again. so I reinstalled 03272011 and waited and it started working as well.
I don't use bluetooth for headset, I use it for my watch. getinpulse.com. The watch uses L2CAP protocol to communicate, and it's all working right again.
Prox seems to be working well, (time will tell..). And yeah, battery life is as good as ever, if not better. Yesterday was 12 hrs on wifi, with a solid ~4-5 hrs of reddit/tapatalk browsing, internet browsing, texting, and angry birds playing, (I was sick on the couch, didn't feel good enough to even sit up enough for laptop fun). I was still at 65%. Brilliant.
A FELLOW REDDITOR! HAVE AN UPBOAT!
...oh wait, AC doesn't have upboat. i r sadface.
i second that i am very pleased with is build awesome awesome job. battery is excellent bin running for 6 hours and am still at 80% all the other build i was only gettin 8 hours on a charge and the prox censor has been workin all day. cant thank you enuff.
Status
