ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
Cool, so I just need to do nand backup, wipe data/cache and flash rom right?
And the debug format zip file thats also found on the front page, ive also confirmed that this rom can be flashed from thunderc on accident so if you dont want to switch to xionia you dont HAVE to, but i like xionia.
Just wanted to say that this ROM is awesome. I do have a question though. Is there a way to remove the email entry under the favorite contacts?
Is this the screen you're talking about? Because I don't have any email option there. Otherwise, just don't enter an email for them? I'm not really sure what you're getting at..
do you have to have blue tooth to use the radio app? i incerted my headphones and im not getting anything. any advice would be great.
Does it work with the speaker? If so, I have a stupid suggestion (It happened to me with my HTC Hero)...plug in your headphones and try turning up the volume.
I have a radio app when I updated to the newest nightly. Have sound for everything else just not the radio.and i dont see a seperate volume. let me clarify that its an FM radio app.
Proximity, wait, what?
Does this mean the proximity issues are now gone?
EDIT - GPS is also passing through to other applications now. I was having problems getting it to go through to the News/Weather widget, and Beautiful Widgets.
If it does I'll be flashing back to this ASAP, I love this but the prox issue was pretty bad for me. That was about the last thing on this ROM that bothered me.
Major thanks to Zefie for all the work put into this ROM, it's pretty freakin' tight.
Yes that would be the screen. I have two entries for one person. One entry having the home and cell phone numbers and the other having the email. I can delete the email but don't want to if I don't have to.
Headset
Can anyone confirm if the headset/headphone microphone issue has been resolved? Flashed aosp cm7 build earlier and most of zefie's nightlies and despite being smooth they've all had the issue of recognizing any headphones plugged in as a headset with microphone which then disables the built-in microphone on the phone. I do a ton of talking in my car with aux out and this issue has made the CM7 builds difficult to work with.
Can anyone who has flashed the 327 build let me know if they have the same issue (i.e., can people hear you when you talk while listening to conversation over standard headphones, not headphones with microphone built in)? Would save me wipe/flash/restore/rebuild and I'd be very grateful.
This is actually fairly easy to resolve. just long-press on the entries that are the e-mail only, and click remove from favorites. It will leave the email address on their contact page/info. and will leave their phone number under favorites, but will remove the email only favorites listing.
Status
Vector
