ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
THANK YOU SO MUCH for working Mobile Hotspot!!! This will be my daily driver now. By the way... for some reason with Quick Settings installed, when you launch Mobile Hotspot it reset my phone. I unistalled it and Works perfectly!!! Thank You, Thank You, Thank You!!!
Things now working that were NOT working: poximity sensor, native wifi tethering from anywhere, ie wireless settings, hotspot widget, notification bar..., camera zoom is stepped.
Things still not working Bluetooth, VoBT & SoBT, fm radio
Strange, are you over clocked?
This post made with Optimus S running CM7 latest nightly and using the tether app downloaded from market. Thanks zefie. :)
Anyone having data problems? I did a full clean reinstalled from scratch and I have no data. Installed 2 different roms to verify its not my phone and its not the phone. Any ideas?
Not sure if this will help. But try updating profile before you wipe data, cache and dalvik, then flash CM7.
Tried that and still no data.
Hmm.. do you still have data in previous nandroids? I've got perfect data here..
On a related note, native wifi tether works perfect, usb tether is still grayed out tho.. fm radio at least 'pops' when turning on, but nothing beyond that. Prox sensor is fine (it worked fine for me before anyway, but still works with this update). I can't test bluetooth audio because I don't have bluetooth headset or speakers, but it appears to turn on and be discoverable, so I'd assume it would connect. Camera slider still won't zoom to 4x, but tapping the screen will do it. Otherwise, rock solid.
So this is it? Everything else is ok? So what it really comes down to is no Bluetooth?
It sounds like this is pretty much a full blown working build. I might have to give this one a shot now....
I think it's just voice/sound over bluetooth. The connection is fine tho. Might as well give it a shot ;)
so strange, if i tap my screen i get a FC, but slider works, and it's the opposite without the FC for you, how strange.
yes, USB tether isn't working either but since wifi is and most if not all devices today are wifi so i'm thinking not too many people are caring.
yes, you can connect a device and even send/receive files, but VoBT and SoBT are still non functional.
Is anyone seeing battery improvements? 10 hours with wifi on has me at 45% with some good usages.
Status
