I was actually about to try that, but I dont have the time for it right now, after being up all night, unfortunately I do have work to attend to.
Huh.. disregard. Guess reflashing has corrected it! Great ROM! Thank you!
are you using a custom/third party launcher of some kind? the only reason i ask is that you're apps drawer should not switch to landscape mode with just this rom.
Call me a freak but I always wipe everything. Why not start fresh and remove the chance of something going wrong. I format my system and wipe cache and Dal, then I run Debug Format. Then I install the ROM. If its this version or ROM that im flashing I also flash the gapps. I do this with my computers as well.. any chance of a virus.. well time to reformat.Is this still working for you?
I had the update just before this one, and just like you, I am seeing this issue now.
Following your advice, I:
Wiped Cache
Wiped Dalvik
Ran Debug format system
Reinstalled new update, and gapps
Still, the issue persists.
The only thing I didn't do was wipe data.
What steps did you do, and is wiping data really necessary to fix this? I'd rather avoid spending time on restoring all my apps\data
Wiped Cache
Wiped Dalvik
I dunno why you get that error message... but I bet its not good. Im too noobish to answer than onei allways get dalvic not found when i try to clear it
I would like to know why you would get that message as well tho.
Anyone>?
