ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
True enough. Also, this pic has inspired me to make a new build tonight. :P It is building now and assuming the laptop doesn't fry and completely die (if you follow my twitter you know that my laptop's built-in audio vanished and usb fails), should be released later.
Pic link broken, we want to see it, post it post it post it.
Just giving you a hard time........
should be ready now
Looking forward to trying it out, sounds like we need to organize a "buy zefie a new laptop" event.
- Sent from my Optimus S
well the laptop is my dev machine/download server now since lacking sound and usb it is fairly useless for a laptop/desktop.
If it dies completely the hard drive will be transfered to my broken netbook, which will serve the purpose for my download server but releases would be fewer since compiling on an atom would take like 6 hours lol
what was my server is now my desktop hooked to my tv via vga at 1920x1080. It has DVI but the nvidia card doesnt support HDMI Audio but sends a blank audio stream anyway thus no sound if I use digital input, meh. I could completely disable the hdmi audio under linux but under Windows nVidia's "Disable HDMI Audio" just changes it from static to silence. doesn't enable the analog. :/
Serves the purpose though as xbmc can do 1080p on here so its my desktop/mediacenter xD.
The Role Reversal was not fun as I had to move over 700gb across 4 hard drives to switch from server (ext4) to desktop (ntfs), but was worth it in the end :)
should be ready now
Download link works, the picture you mentioned in the previous post didn't. Thats what I was talking about.
OK I have a rooted Optimus S, and am wondering a few ?s.
What can I gain from installing CG7? Speed? Space?
What will I lose? (saw something about 145 chars in sms?)
Will I lose all current data? and can I use Rom Manager?
You gain speed for sure. Also, CM7 is kickass at managing space, automagically installing everything it can to SD, seamlessly....it was the first ROM on which I could download tons of ****, and never hit a "out of space" limit. Note that the internal 160 mb of memory is still the max.
You'll need a better messaging app to get around the 160 char limit, like GoSMS or ChompSMS or HandCent or something else.
You should use Titanium Backup to keep all your apps as you migrate over.
I have no idea what Rom Manager is....but I'd say just follow the instructions in OP. If you go off on your own, don't come whining when it doesn't work ;).
I believe Rom Manager only works with CyanogenMod supported builds. This version is not there yet, but may be, who knows.
My clockwork mod wont varify signatures and aborts installation aborts when installing a zip from SD. Running your cm7 nightly test runs great on my rooted optimis s! With your xionia cwma.
Thanks for the early new build zefie (: May I ask how exactly did that picture inspire you?
Since CM7 is not beta anymore, does this mean there won't be a frequent update? Not that it really mattered to me since I hate bluetooth but was thinking about the future.
Thanks for the Camera update.. Ima Flash it now to see if mine is working better now. I have only had issues with the camera. Thank you for adding this to your new Nightly Builds. I now have something to be excited about today!
YOU ROCK ZEFIE!
once they slow down and/or quit updating upstream we can focus harder on fixing problems instead of fixing stuff that broke in an update ect
Reactions: liquidmass
Ok so I know this has alresy been ask prob but can anyone tell me a good launcher IV been using ADWlauncher but it getting a little old an Iv tried the new spb shell but its nit from the market so it closes so I was just wondering if anyone had any sugestion
Don't pirate apk's. It's a bad habit. SPB shell is pretty neat, but i returned it, not worth 15 bucks. Launcher Pro is my favorite, and I've tried adw, zeam and go. But a lot of that is personal preference. I also have the plus version of Launcher pro, so i get some bangin' widgets. If you wanna see what my launcher setup looks like, go to the post your homescreen thread and look for my post.
...or edit your post with a link to it, maybe...
Your post is easy enough to find, just sayin'
-Click on handle-click on all posts by handle-look for homescreen thread-click on post name-
Google Voice Double Load
Has anyone else ran into Google Voice double loading? What I mean is, i press the voice icon, it takes me into my message list. But when I back out by pressing back, it shows my launcher for about 1/4 a second and then back to message list. Back again successfully exits the application.
Same here. Just started hitting home button instead of back......
Status
mattellis99
