ARCHIVED: [DEAD ROM] ThundeROM V1.8.3 4/5/2011
Status
Not open for further replies.
Thanks for the quick responce. This custom kernel how much does it allow you to OC the phone I'm seeing up to 864 or something like that is this correct. I highly doubt I'll OC that high but JW. I believe I saw that the cpu speed was set on boot MAX 745 and MIN 245, is this still correcet, and do you recommend using set cpu or leaving it the way it is? How does the phone seem to be running at these speeds? Last question and sorry for all these questions by the way. I know each phone can differ from each other do you or not recommend installing the 600 CPU kernel.zip I saw floating around here and ajusting it my self, or is that something I'll just have to see if the phone like or not on my own? Thanks again Nate
Both can go to 864max. The one included is set to 748max/245min with interactive governor.I run without setcpu most the time. The Boot 600 is there for anyone that doesn't want to run OC'd.When i have my phone set up and running the way i want i run the 600max cause it's set to interactive governor and i get great battery life. Play around with it and see how things go but i can go all day using my phone and not have to charge it running either speeds.
I would say this is a isolated incident. I use to have the hero so i know what you mean. I haven't had any problems with gmail with optimus.[/QUOTE]
I am continuing to have this problem...just to refresh your memory...I am running into the bug where I'm not being notified of Gmail. I either have to reboot the phone or force stop the application. Can you look into this or give me some guidance on how to fix it? There was even an instance today where I refreshed my phone and it didn't pull up new email.
There's nothing we can look into. The problem is isolated to you which means its an app, setting, configuration that you've made. The only thing we can do is make suggestions
Do step 1 & 2 first
1) If you have juice defender, remove it and reboot
2) If you have any form of task killer/manager/destroyer/(insert ominous description), remove and reboot
If step 1 & 2 don't work then do 3
3) Menu > Settings > Applications > Manage applications > all tab > scroll down to gmail > Force stop, clear cache, clear data.
If step 1, 2, & 3 don't work
4) Download the ROM, go into recovery, wipe cache and dalvik cache (not data) and reflash the ROM overtop of itself.
So are you not recommending min free manager anymore? I will try this because for some reason my battery is getting destoyed...my phone is only sleeping 45% of the time and I'm hardly using it. Spare Parts isn't showing any app misbehaving either.
Delete it, you don't need it with this ROM. We've done their work for them. Delete, reboot. But a min free manager isn't what i was talking about. I'm talking specifically about task killers, destroyers, demolishers, ....... those. Anything like that delete and reboot. Anything that can control your data connections like juice defender or whatever, delete and reboot. Basically what I'm getting to is something on your phone is causing this. A setting, an app a something. Long story short, delete the unnecessary gabagio, to start eliminating stuff.
Do everything i listed 2 posts above, in the order i listed and you're well on your way to finding your issue.
Regarding your battery. There is a thread on [How-to] Troubleshoot bad battery life. If i had to guess, you have an app with a wakelock problem or one that polls too often. Both of which waste battery.
What's the average score for ThundeRom using deluxe build.prop SetCpu Interactive at 748/245? Seems like mine were pretty high last night and have dropped today.
There's not really a set score you should get. It can go up and down. If your getting above a 900 then i wouldn't worry.That's really just ran for fun.
Ok thanks! I was just wondering if I did something wrong. I appreciate how fast you respond.
Another thing I noticed after upgrading to 1.4 is that the Hotspot Widget does not seem to work. When I add it to my desktop, instead of seeing the bar at the top of the widget that tells you if it is on or off, it is just a blank grey box. Pressing it does nothing. I uninstalled it and reinstalled it from the market, but it does the same thing. Going in to my wireless settings and trying to enable the portable wifi hotspot there gives me a "network is unavailable" error after thinking for about 5 seconds. 3g data and wifi do work independently, so I think it is an issue with the tethering itself.
EDIT: I don't mean to come across as ungrateful. It's a great ROM that I will continue to use, I just wanted to give my feedback as it looks like I'm one of the first to install 1.4 since you released it only about an hour ago.
EDIT 2: rebooting the phone cleared this up
Rebooting didn't clear up the tethering issue for me. Does anyone else have the problem?
NEVERMIND, yes it did.
I read several pages on this thread about the voice search and I see the stuff about it not working, but I prefer the Android Keyboard Not the swype. My Mic button (on the side of the phone) only works on the swype board now. I see the one next to the space bar and it wrks on the Android keyboard and I see how to disable it in the settings but I want it to work with the button with the A keybrd.
Will installing the market version fix that or am I doomed to live with out it now. :)
will read a few more threads later.
The keymapping won't work with the gingerbread keyboard at all as phones (other than ours) dont have this button. Thats a modification that LG will have to make prior to releasing GB. If it were a standard button it would work.
I have had issues with market before and I found out it was a problem with my sd card. Today I started having issues again. When I go to update or install an app it says downloading never does anything goes away and the new our installed app shows price. Before the only problem was with stuff on the sd card, now it is doing it with everything. I have tried rebooting, clearing market cache and data, and removing the sd card and trying all again. Any ideas would be much appreciated.
just sensitive
Proximity sensors on Android phones are notoriously crappy. In fact, didn't a blogger recently mention that he tested an Android phone that actually had a working proximity sensor and that was a major selling point for him? I'd have to look for the article, if i find it i'll post it because it was funny.
Anyway, long story short, we havent touched your proximity sensor. It's sucked from day 1 and will continue to suck. No need to return the phone ;)
Cheers!
Not disable it but set the distance for it yum (who talk with the phone 4" from your face >.> anything other than on mah ear, well that is so speakerphone button or bluetooth. does this phone have a service menu to calibrate the sensor like the Lg media phones did?
KSmith...do you know what Sprint VV is listed as in this rom? I pulled a ls last night through command prompt to remove it because I use Google Voice and couldn't find it.
Also, are the commands in ADB the same as they are in other devices for removing apps? If not, can you please tell me what they are after I get the list and #?
Status
