tested, flashed fine
So if we flash this we will not be prompted anymore to update? Also, does this mean that the build.prop deluxe will not be able to be used anymore?
yarr it works.
deleted cache and bounced the phone after flash.
manual attempt to update came back "phone is up to date".
thanks!!!!
Go back one page read my post,I made it so all the zips get replaced with zips that are good and updated.
Sorry, I guess I don't understand. I flashed the OTA zip...went fine. Update hasn't came back, but I liked how my phone performed with the deluxe build.prop. I suppose there are bigger issues right now though.
It's okay let me explain better. You flash the zip i attached on that post it's going to replace your current build.prop with the default one that comes with the rom with a couple edits to block ota. I updated the zips that get pushed to the sdcard with the same edits,so you can flash the deluxe build.prop if that's what you want and it will have no bad side effects. It will block ota from poping up too.
Anyone have OrbLive working with ThundeRom?
OrbLive worked great when I was stock, but since flashing with ThundeRom the video streaming portion no longer works.
Access to audio files / pictures on my pc thru orblive - no problem.
Uninstalled/reinstalled Orb and tried some of the different buildprops as well.
Still no video streaming!
Anyone have a solution?
Great, thanks for the explanation. I appreciate you breaking it down for me. Now, from reading your other post, am I understanding correctly that our phones will stop working correctly if we don?t get this update from Sprint?
Thanks!!!! Deluxe was the one I hadn't tried yet.Try flashing one of the build.props on your sdcard probably the deluxe one.
Is there any instructions as how to flash this? I have no custom Rom's installed (cause i suck at it lol) and i really want to stop this annoying update notification.
Thanx in advance!
Flash the attached zip in recovery to disable OTA's from popping up and being able to install!!!!!!!!!!!!!!!!!!!!
Thanks smccloud and m3rp for testing.
@ ANYBODY!!!
I need one person to download the attached zip and flash it. It will replace you build.prop,all the build.prop's on sd,and rename the ota security check so that it cant install even if it sneaks back in.
One person please post saying "testing" then come back and say if it flashed without issue.Then everyone else can flash and i can add to first post.
There's not really any risk of anything going wrong i just want to double check it flashs without problems. Whoever is nice enough to do this if you have any problems just flash thunder on top,sorry i would but don't have a phone yet.lol
@ ANYBODY!!!
Did I read something about moving the otacerts.zip killing the battery because it makes the phone download the update over and over when it fails to verify?
