- Oct 7, 2009
- 3,536
- 1,441
- 0
I've never butt-dialed anyone...only butt-texted!! LOL
Yeah, done that too lol. Check your PM box
Alright, I did a full back down to stock everything... using the Nandroid I had backed up.
I updated to VC then to 1.7. No Problem's.
So 1.6.2 V9 to 1.7 VC is not good, you will get many problem's.
My Quad score is back to the 1k+
I have been running 1.7 for awhile now... If you have flashing capabillities the update does not harm them, you will lose root due to the OTA.
BUT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Do the OTA update, shutdown phone.... start up BIOS and flash into TR 1.7. It will reroot the phone.... PLUS you will have 1.7.
I have done it already, and I am running fine. I have root, I have minfreemanger running perfect again. Everything for me is G2G, plus I have had no SD card dismount's.
P.S. After the TR flash it will put to more packages into your sd dir, I flashed TR 1.7 then flashed TR Deluxe.
This is promising! I hate rooting. My phone took forever, but my husband's...only 2 tries and I got it! I must have done mine like 200! LOL
I do too, but I did it anyways like a idiot xD.This is promising! I hate rooting. My phone took forever, but my husband's...only 2 tries and I got it! I must have done mine like 200! LOL
K or B If you will please make a small fix for the mapping of the button's. This is driving me crazy...
So people can choose with that would rather have. I know this is both of your's, but I really don't want another ROM. I like this one, everything about it is great.
Figure id report in here.
Flashed from 1.6 to 1.7 but with on problem, I couldn't get 3g access.
So after a bit of dark mubbling I figured I should reflash and everything worked fone after that.
Even the annoy OTA notifications stopped and my phone is up to date. Thanks guys so much for the lastest update and all the hard work that goes into this rom.
I see a lot of posts from people stating they want to see various features added to this rom, however, I don't believe there are any "should or shouldnt's" for this ROM, as K and B have stated before - This ROM is their personal preference which is why they were kind enough to work on Lego Rom, making endless possibilities via custom zip flashes. So, i guess it's up to them if they take requests on their own preferences![]()
So you can run the LG updater even with a custom recovery? Couldn't you just restore a 1.6.2 backup after getting to the vc baseband then flash 1.7 over that and have all your stuff?I do too, but I did it anyways like a idiot xD.
Run through my step's, I had a Nandroid back up from before I went to ThundeROM. I rooted my phone and got flashing to work. So I had stock everything. I ran the Nandroid back up.... So I was on V9, everything stock.
Plugged my phone into my PC. Ran the LG update... (took forever). Restarted my phone made sure I had updated System Updates, Firmware, PRL, Profile.... Shut down phone. Flashed to TR 1.7, then flashed again the Deluxe Build Prop (Which come's with TR 1.7 after you flash it unpack's it.)
Started up phone and had 1.7, rooted.
Only thing that sucks.... is you have to get on your apps n stuff back.![]()
This is a good idea. Can anyone confirm if the VC update * requires* going back to stock (stock room and recovery, unroot) or can the update be applied via the LG update tool as is?
