Dialpad not working during phone call?
Samsung Note 8 - Sprint - 31 Aug 18
DTMF did nothing. Had to turn off wifi calling/calling plus. Annoying because now I keep getting spammed with notifications to turn it on. Hope this helps
Hey!!! Thank you very much!!! Just wanted something in case someone else has my same phone. I have just bought a galaxyS9+ and I found how to fix it while searching for "touch" while in settings.
Tap on Touch and hold delay and change it from normal to long.
Hope this helps someone!
Thankyou! Been stabbing away at the phone with no luck. Your fix worked on my Note 9!
Thank you so much you saved my life.
I have Samsung note 4 and for those who don't have "phone " in their settings you just
- tap application
- call
- DTMF tones
- choose long
you're welcome
I do have samsung Galaxy s6, but I am not able to find to DTMF Tones,? I went to setting and choose phone but there is no such option for DTMF,
Welcome to Android Central! Open the Phone app first, then tap Menu>Settings, and look through all of the Phone app's settings (not the system settings).
Diluoyha
