[Discussion] CyanogenMod 10 Fixes and Tricks
settings->developer options->checking "dont keep activities" and setting background process limit to 1
This lets phone go into deep sleep and creates better battery life. in 2.5 hours i dropped like 20% instead of like 60%
Reactions: Fraslin#AC
Very good info. Thank you.
Dark I was good until I decided to connect the power cable to the phone. Once I disconnected the power cable the wake locks started. My log cat is still at 0 bytes I must be doing something wrong.
Edit: what are you guys getting your logs with?
Sent from my SPH-D710 using Tapatalk 2
Well I rebooted the phone and now deep sleep wont work again. Gunna odin and flash again to see if I can repeat the deep sleep
For everyone wanting to use Google Now. Google Now is fully functional as long as you do not hit the Google browser. If you click the Mic button then it will appear... But if you use the STOCK Browser I think it will still work but I haven't tried it yet... If you have already clicked on the google browser than all you have to do is re-install the CM10 and then you're done... Just do not hit the Google browser.... :cool:
After flashing beta3 signing in, installing cpu spy and going to settings->developer options->checking "dont keep activities" and setting background process limit to 1, i got deep sleep back. After reboot deep sleep wont happen
added a battery tweak to the buil.prop
made to put phone into deep sleep and seems to work for me. ill post in other thread for people to test
battery tweak
#Battery Life ro.ril.disable.power.collapse=1 pm.sleep_mode=1 wifi.supplicant_scan_interval=150
battery tweak
This seems to be a temp fix also. los, and wake lock are preventing it from staying
Ok everyone. This thread is only for tips and tricks to get CM10 stable on the Epic Touch 4G. Please dont post anything like "Awesome work" or "Flashing Now" ONLY POST TECH AND FIXES AND LOGCATS. ITS A PAIN IN MY BUTT TO SCROLL THRU A TON OF NON SENSE ON MY THREAD. PLEASE DONT POST NON SENSE. THIS THREAD WILL BE HIGHLY MODERATED BY ME. ALL NON RELATED INFO WILL BE REMOVED AS I SEE FIT.
Now lets get Jellybean stable on our device.
Log cat for face unlock setup in settings not working at all.
Rc1.5/ff18
Emailed to you
Downloading drop box so I can just upload them going forward.
OK drop box setup here's the link
http://db.tt/D34D5x5w
RC1.5/ff18
XDA tether app. Installs but won't broadcast WiFi signal. (Figured I'd get a log cat in lol)
Log cat:
http://db.tt/zXTeRpVh
does anyone know how to recover files deleted from my phone. like pictures i took of a cheating wife.
also my phone came with a voice recorder application and i recorded something that my cheating wife deleted, is there anyway to recover that?
thank you any help would be much appreciated it.
chris
TechEnthusiast88
