Discussion of the Fascinate root How-To
i am sorry no my friend sent me a link from fascinate forum on how to root my phone go ahead you can yell at me lol................
Hi I've never rooted my phone before and am not quite sure what to do. I'm coming from stock EA 28 but wood like to try out super clean 2.8. What do I need to root? Will I lose all my text messages I have in the process? Can I back up my phone in case of trouble? lol help someone
I've merged your thread with the rooting help thread. You can also checkout this thread by Sheepdog Elite and this thread by DroidXcon. After checking those out, please post here if you have any further questions.
A lot of people spend a lot of their time creating threads that answer all of these questions..
Sent from my SCH-I500 using Tapatalk
You're right! And the best thing to do is link to said thread, instead of generally referring to it :)
Reactions: Landshark
Thank you both every much I have research and researched sent him lots of links he should be here in the next hour I pray he has fixed it. Thanks again for your most helpful time, I hope he was successful bcuz I'm scared :O)
Check your in box please
Sent from my SCH-I400 using Tapatalk
ok. be a bit more specific on what you are doing and whats happening. the more info the better.
Just wanted to say thanks for the help last night. I was getting ready root my Fascinate with Odin but decided to try the one click method one more time and it actually worked. So now I need to figure out what I need to do next. Thanks again for your help.
check out thr superclean 2.8 thread. its a great rom.
problems rooting my fascinate
ok i am running the "one click root" file. when i click continue after i hook up the phone, it lists every root file and says "is not recognized as an internal or external command, operable program, or batch file...then it does nothing. doesnt reboot phone or anything. waited a FULL 5 minutes and still nothing. what am i not doing correctly?
are you able to copy and paste the read out for me?
oh and welcome to android central
well. i think i messed up. i thought i still had dl09..but i have ea28...that could be the issue. lol
* Dirrk's EZ Root v0.2 (Sebastien Krahmers Exploit) *
* Testing if your device is connected
'adb' is not recognized as an internal or external command,
operable program or batch file.
* If you are NOT connected please follow these directions
* Install the correct drivers
* Turn On Debugging
* Check usb port, cable and phone
* Then rerun this application
Press any key to continue . . .
* Pushing the files to your phone
* rage.bin, busybox, Superuser.apk, su, com.sh
'PMSLEEP' is not recognized as an internal or external command,
* Restarting your phone to ensure the exploit will work
* When your phone comes back on please unlock it if it is locked and then
* wait for your computer to properly connect to your phone it it does not
* unplug make sure media sync is disabled
did you download and install the drivers,,,,is your phone in debugging mode, because according to that read out it is not recognizing your phone being connected
actually , redownload the root folder again and delete the one you are currently using
vinod681
