Discussion of the Fascinate root How-To
ok that tells me that your USB port is not busted...
Samsung
try these different set of drivers, try that trick i told you
while plugged in the entire time restart your phone and wait about 2 mins, then try to mount the card
ok it recognizes and i am mounted, but wont mounting prevend ABD from being able to push anything?
after it reboots, and if you cant mount unplug the phone for a couple seconds and plug back in , then try again
weird now when it rebooted i get a verizon wireless pop-up:
software is available that will help your Atlas (SCH-I500) communicate with you PC. Install now?
i dont use that stuff, thats up to you i heard it works, im sure it loads all type of verizon stuff up
i didnt update. but were still in the same boat should i try a different driver? i have tried 2 so far. i think there is one left
none will work the way you want it to , just stick with the one that let you connect,,, later on you can try different kernels to get it to work
ok i tried reinstalling all the drivers and the other 2 wont mount at all so im back with the one that will only recognize with mount only. im thinking im SOL
if it recognizes with mount than you can get a Adb connections... you should just upgrade to froyo i am going to try to make a video tonight on how to do that and hopefully have it by tommorow
or you can follow written instructions here
http://forum.androidcentral.com/ver...available-now-includes-full-instructions.html
in froyo this usb issue seems to be resolved and once you flash froyo you will automatically be rooted
Reactions: ronincurrysan
cool ill wait for the vid ive been at this issue for about 5 hours and im going to seep on it. thanks for all you help seriously!!!
My phone is all stock with the DL09 + rooted + titanium backup (froze all the bloatware)
If I do the update for EA28, will it cause any error? Or do I have to unfreeze my apps and/or unroot to do a successful update??
Thanks.
Thanks.
Skip ea28 and flash the dl30 froyo. It's very stable in my experience. It will fix the bugs. If you want ea28 defrost and ota the ea28. You may lose root. You made it this far though. Happy flashing.
I'm hoping someone can help me out. I'm running EB01 (FROYO) and am having issues trying to root. I've used FascinateR00t_V02 to root previous builds and it worked fine in the past. I'm just having issues trying to root EB01. After the final reboot I don't have root access (tried launching Titanium backup and Root Expolorer). Here is what I am seeing after running Start_Root.bat
* Dirrk's EZ Root v0.2 (Sebastien Krahmers Exploit) *
* Testing if your device is connected
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
I5000090c1b2 device
* If you are NOT connected please follow these directions
* Install the correct drivers
* Turn On Debugging
* Check usb port, cable and phone
* Then rerun this application
Press any key to continue . . .
* Pushing the files to your phone
* rage.bin, busybox, Superuser.apk, su, com.sh
1606 KB/s (1867568 bytes in 1.135s)
657 KB/s (26264 bytes in 0.039s)
1776 KB/s (196521 bytes in 0.108s)
164 KB/s (5392 bytes in 0.032s)
4 KB/s (281 bytes in 0.056s)
* Restarting your phone to ensure the exploit will work
* When your phone comes back on please unlock it if it is locked and then
* wait
* About to exploit your device
* This will take about 3 minutes
* If it doesn't respond after waiting 5 minutes then it probably failed,
* so you should close this and run again
* Start Time: 17:58:14.90
** Successfully exploited, installing permanent root files and deleting temp fil
es
mount: Operation not permitted
/data/local/tmp/com.sh: cannot create /system/xbin/su: read-only file system
/data/local/tmp/com.sh: cannot create /system/xbin/busybox: read-only file syste
m
/data/local/tmp/com.sh: cannot create /system/app/Superuser.apk: read-only file
system
Unable to chmod /system/xbin/su: No such file or directory
Unable to chmod /system/xbin/busybox: No such file or directory
* Restarting your phone now.
* Complete
Why are you trying to root all the EB01 leaks have root preinstalled
I5000090c1b2 device
* Turn On Debugging
* wait
es
m
system
* Complete
Sent from my SCH-I500 using Tapatalk
StevieD49
