My droid 2 is having issues connecting to Wifi it connects but is getting network errors. 3g is working fine.. Any things I should try?
If its your home network you might want to try using Wep.
I had the opposite happen: WPA2 connects fine, but WEP (darn TiVo) gave me problems.If its your home network you might want to try using Wep. When I first set up my phones wifi I used a Wpa secured connection and would get error messages like that. It would connect on and off and then I would eventually get the network error. Switched the router to a Wep connection and now I have no problems.
