DX Top
I really like that he made the icons in the sliding drawer larger. Not sure which version implemented this change but its a plus.
Hey guys, don't know if you've gotten it yet but there is a new dxtop update and you can see the icons for the mini dock apps are bigger now. (you can compare my pic right above this one to see the difference)
I just downloaded dxTop and its cool. How do you setup those mini dock icons? Where do you get info about its features?
Slide your two bottom tabs to the left or right, it will give you that space for
5 extra icons.
i think it was in the latest update.
i agree, i didn't even know i could have 5 icons until they were made bigger
WTF guys, really. I have uninstalled this program 5 times and I still can not get the screen to work. I can't install apps and once I'm there I can't swipe to make it go away. What version are you using?
Version 412070410 is what my phone shows.
Version 2.5.2 is what the Market Place shows
That is the latest.
Kind of a bummer. hope it gets fixed quick. I got it mostly b/c i want to get rid of the pop up draws when possible. oh well. it does all look a lot better! and with beautiful widgets its very nice
ive got dxtop and cannot get it to work right, once i slide the 2 drawers over and it says long press to add applications, it gets stuck there and wont let me add any apps and it wont let me slide it back over to the drawer view, ive tried installing again and nothing seems to be working right, any ideas?
I gave up on dxtop. Sad thing is, i uninstalled it from the market and got my refund and then re-bought it and installed it trying to get the dock to work! Now i cant get a refund!! I hope that they get the issues worked out b/c other then the dock it worked really well!
Thats good. I am going back home for thanksgiving and looking forward to showing off my new phone!
Other then the dock the app works great. I think the only other real issue i have is what to do with all this space!!!
I emailed the dev of DxTop in reference to the "frozen app bar" at the bottom that a lot of us are experiencing. They are very aware and working on an update to fix this issue.
Also I liked how a lot of people in this thread are using DxTop, it really is great. It would be perfect if it didn't have to redraw the widgets like it does. With that said, I tried GDE (the cube looked cool) and it was visually sweet but in my experience not as stable many force closes. Oddly enough, opening the app menu/phone application/switching to contacts/opening programs seemed snappier with GDE than with DxTop. I went back to dxtop because of the app drawer "categories" and I've gotten used to the single swipe to get to a screen. Also, I found the cube transition caused some slow down sometimes.
Need a little help for anyone with dxtop experience. I am using the peace and war theme. I really dont like the icons though. is there any way to use the normal android icons with the rest of this theme? i tried appearance -> icons -> No icon pack and it is still the same.
thanks for any help
EDIT: nevermind. just did longpress -> change icon
noroldie
