DX Top
On another forum the members talk great about GDE and not so good about dxTop. Here it is the other way around.:D
Need a little help for anyone with dxtop experience. I am using the peace and war theme. I really dont like the icons though. is there any way to use the normal android icons with the rest of this theme? i tried appearance -> icons -> No icon pack and it is still the same.
thanks for any help
EDIT: nevermind. just did longpress -> change icon
what did you change it to? i wanted to replace the dolphin browser with the default icon....
If you go to appearance ->icons-> get icons
There is an android 2.0 icon set and that has everything including the original browser
Update is out
Just downloaded and it works great! The icons also didnt change with the update. I am very surprised that they got the update out the same day they found out about the problem! very good app IMHO
They are adding another screen?? Wow. 4 screens is already a lot more room then is really need for me. Wonder how you would get to the 5th screen? maybe just the home button and then swiping from there.
That's what I think. Hit home get to the middle screen and slide out to the corresponding screen.
Nice, working again on my Droid. I really like this better than any of the others I've tried out.
i just downloaded and i dont really get this....so this just gives me more home screens? i mean what else does this do? up down left right?
I speak to the dev via email. Wonder how the 5th screen will work?
When are they going to add the fifth screen? And will it be in the middle of the lot of them like three horizontal, one on top, and one on the bottom?
That's the one thing I was waiting on before I purchased it :D
did you read the first post at all?
Nice. That is all it was missing. It looks sharper than WWD right?
i think it does, i use WWD for a small weather icon for a different city and it works well for that, but i like the BW clock better
Takes screen shots
Hides apps
Allows you to change icon images
Lets you kill apps
Allows you to run themes
Lets you organize your apps in the drawer
Allows you to slide the tabs out the way and add 5 more apps
Lets you rotate the screen without opening the slide out keyboards
He gets a lot of requests for that middle screen. I think it will come soon.
BekaH
