DX Top
I love LOVE Dx Top. This application has seriously renewed my faith in my Droid. It's clean, it's easy to use, and keeps things very organized.
Home replacement app in the market. Most in this thread are using DxTop Home. That's how we get the two drawers (or the 5 icons row beneath other icons). The flip clock is from weather widget - donate. And wallpapers are from various places.
When I posted my screen in the other thread I had to usb it over to my computer because I couldn't find the screenshot in my gallery. Am I missing something, can you not access straight from the sd card on the phone?
@youngchrisg....I would pull the trigger on that purchase, middle screen on not!
On BW what do you set sunrise sunset to. Official or Civil?
official
10char
you can find it if you use a file manager to open it, but i guess the gallery app doesn't look in the root folder for pictures
click menu, the dx top settings button and uncheck the option concerning their lock screen.
I use dxTop.
From your Twitter widget on picture #1: "visitidaho: DowntownBoise Tis the season!"
This just plucked a string in my heart. :D
I wish that when you had the icon bar across the bottom instead of the drawers that you could just slide your finger upwards over the icon bar and get the main drawer to slide open... it'd be a nice feature because honestly... i like the icon bar and never want to see my slider tab again (just takes up extra space IMO)
:-) ... I spent the summer there ... well in Nampa but basically Boise at night lol.
I actually didn't have the icon bar because it froze the last time I did that. However I just installed the new update they released this morning (took the pics before) but it fixed that and I now have the icon bar. That would be nice to be able to access the drawers by doing that though. It was so weird to not always have my phone accessible with a touch so thats the first thing on my icon bar!
Its a program called dxTop. Look for it in the market.
Yup .. I believe there is a trial but something about restarts every 30min. The real version is $3 and is probably one of the most useful applications so far that I have used. I would definitely recommend it and they are very good/quick about fixing bugs.
I paid for it and tried it, got to the App bar on the bottom, and couldn't put apps in, nor could I get rid of it. Had to uninstall it to get the phone working again. Since that bar was there (app launcher I guess), I couldn't delete some of the icons on the home screen either, as the trash bin was no longer present. If they fix that, it seems like a winner.
Mark
First problem with it I've had....woke up this morning and all the apps I had put on the right screen were gone and powercontrol widget on my home screen disappeared. Seems to take a little longer with reloading the widgets since the most recent update.
Mark
You have to slide back to the two tabs in order to slide things off into the trash, you can't do it if you have the mini dock on the screen.
That is weird. :confused:
Gamecraftor
