Fed up with stock battery life
icebike,
I took your advice and did the above. it really did not improve a whole lot. being a new user of this phone and an avid forum contributor for previous phones i will experiment a bit. *edit ​there is a learning curve i believe But this is down right terrible, but my q9c used to be the same way until i made some serious stock changes. -this new generation may involve rooting, but with my job i am concerned about security of my information
I just got an International One X 3 weeks back and I was facing the same problem. My phone would hardly last 6 hours with continuous wifi and moderate browsing with screen time of around 3 hours. I was also compelled to buy the ultimate version of Juice Defender. After browsing some threads some people suggested getting rid of the weather widget. I have been experimenting with different settings since a few days and only today I got rid of the weather widget and installed the fancy widgets. Look at the difference it made :cool:
I am using a live wallpaper, auto sync, music on and also poor reception in the following screenshots.
This is after I installed Fancy widget and got rid of the default weather widget:
This is after I the got the weather widget back on the home screen
And this is after I removed the weather widget again.
My battery dropped from 84% to 80% in about 5 mins after getting the default weather widget on my home screen, whereas it remained on 85% without the widget for 46 mins(1st image)
Absolutely shocking how HTC still hasn't addressed this. I was contemplating returning this phone because of the piss poor battery life but thankfully I've found a fix after researching. I love this phone and its even better now :D
Let us know if this works!
I just got an International One X 3 weeks back and I was facing the same problem. My phone would hardly last 6 hours with continuous wifi and moderate browsing with screen time of around 3 hours. I was also compelled to buy the ultimate version of Juice Defender. After browsing some threads some people suggested getting rid of the weather widget. I have been experimenting with different settings since a few days and only today I got rid of the weather widget and installed the fancy widgets. - - Let us know if this works!
*cut the quote a bit for space, see above post
As I said earlier, I am still tinkering with it and testing out different things and fortunately I can charge my phone while I am at work.
Today I am turning off
  • auto sync
  • wifi (the signal is not nearly as good at work on my hox as it is on my optimus s which could be increasing the drain)
  • removed the weather widget and turned off the auto sync weather when the widget is loaded and set to have it sync every 6 hours
  • disabling google maps until i need to use it
How did you change the weather sync option? I couldn't find that one. And how did you disable maps?
For me, the maps thing is unnecessary because even though it says the maps are draining the batt, it's really the weather, but ymmv.
Find the weather sync stuff under settings_accounts & sync_weather - And disabling maps settings_apps_select all tab_google maps then uninstall updates and then find it again and you can disable it.
Ooohhhh, cool. I didn't know you could do that. Would there be any advantage to disabling the bloatware apps that I don't use?
I personally disabled a lot of the apps I don't use. A lot of them I noticed were starting automatically and saw them in my task manager. Like I would never use the car app (saw running), live tv, att hotspot (often running), etc.
Is it normal for the screen to consistently use 65-70% of the battery? Brightness is set to 25%. Added two screenshots.
Sent from my HTC One X using Tapatalk 2
Yes.
Screen is the biggest battery user. Those numbers are perfectly normal.
You had your screen lit up for 3 and a half hours. That's relatively long.
Sent from my A700 using Tapatalk 2
I like easy battery saver for this. The only setting I use for it is the one that adjusts screen brightness.
It does that pretty well for me while the stock setting doesn't, and now my screen uses a lot less power.
*#*#4636#*#* will allow you to access the radio band setting on the att version
Are you sure any changes made there stick? In my experience they revert very quickly.
Which changes?
@Acles003 The screen uses the most batt but there may be something going on because nothing else is using much power.
Did you just have the screen on the whole time? There is a thing someone mentioned where the screen doesn't turn off correctly and uses a lot of battery. Three Hours of screen time is good, but it seems like you would have something else running, unless you just like looking at your wall paper a lot...
It seems like whenever I'm playing game, even just a simple running game the battery seems get to excessively hot. When I have the phone charging and playing a game it can get upwards of 119f. Is there something that I'm missing?
Sent from my HTC One X+ using Android Central Forums
I was playing minecraft and noticed the same thing, I think it comes with the territory.
got to say as long as i stay away from games its fine. 5 email accounts ,weather, wifi always on, location should add stock4.0.4 unrooted
Wow I wish my phone went even 15 hours with wi fi continuously on.
Sent from my HTC One X using Android Central Forums
I don't mind it coming with the territory but what's the point of having a phone this powerful if we can't fully use it. The phone overheats when playing a simple game and then gets to the point where it won't even charge. As great as the phone is I'm really questioning if I'm going to keep it. I had a vivid previously and could play nba jam while charging and downloading updates with no problem. This was supposed to be a upgrade but I feel like I can barely even use my phone like I used too. Just from typing this and charging I'm at 98f.
john_russell
