androidluvr2
- Mar 4, 2013
- 1,018
- 0
- 0
bluetooth works for me but the radios are worse for me.2 questions...
can this be flashed to a unlocked and rooted phone with no issues? also does blue tooth work? any issues yet?
did you also flash a gapps package and of so which one.bluetooth works for me but the radios are worse for me.
I don't even know what that is!did you also flash a gapps package and of so which one.
I have never flashed a factory image ROM but I have been flashing custom recoveries, so whne you flash a custom ROM you also need to flash a gapps file (google apps) file too. maybe if you use a "stock" ROM there's no need. I am interested in the flash because I can not get the Blue Tooth to work with the new custom ROM.
Can anyone else shed some light on this?
Thanks
You should become acquainted with the Dark Arts of Flashing before you venture into such territory.
May I suggest my Don't Panic guide, listed below?![]()
You need the Bluetooth Fix, most likely. I saw it listed in a Carbon thread on Rootz and again on some AOKP thread. I'm standing down from 4.2.2 roms until that's fixed. My life (err commute) depends on Bluetooth!
I tired the fix but it did not work for me. I tried to go back to AOKP Milestone 1 and the 2012-12-12 gapps but the phone locked up guess i could not go back to 4.1 after a 4.2 flash.
Bluetooth fix should be in place on the AOKP 4.2.2 builds now. They commented that once the 4.2.2 merge was done it would be fixed. Well they are on their 2nd 4.2.2 build and 4.2.2 is officially in AOSP now and no mentioning of the bug remaining.
I'm running the latest. I haven't turned on BT to see if it links to my wife's car but judging from what I saw in the code submissions on AOKP's updates it appears they have added/merged in all the BT stuff for 4.2.2Only one way to find out.
Not yet. Wife's car is buried under almost a foot of snow plus take into consideration for overnight drifting...So you haven't used that one way to find out to actually find out?
Okay. Here's what I got...
Running the latest AOKP with the new GAPPS 2013-03-01. No patches, just flash and profit
Ran outside and Sync'd right up via Bluetooth to my wife's 2010 Ford Fusion Hybrid phone and audio system.
FWIW, I'm using the Sprint GNex but the AOKP builds should be identical. Played a quick song from my phone over her system and checked my voice mail using the phone system in her car connected to my device.
