Mike Dee
Ambassador
- May 14, 2014
- 23,505
- 420
- 83
As I posted in another post I've found that this has to do with moisture on your fingertip. If your fingertip is dry (as it's likely to be in the winter with very low humidity levels) the FPS works very inconsistently -- if at all. Just moisten your fingertip with some lotion or a bit of saliva and it works like a champ. I imagine that this won't be as much of an issue as we move into warmer weather where the humidity is significantly higher. But in the dry winter, this is going to be the solution to getting this to work. And with this, it works 95%+ of the time.
It's been discussed here in this thread for a few days....not the saliva part
