Froyo ETA Set
I fixed my problem with the error 7 logwrapper thing.
It has to do with Koush's recovery.
What he did was replace logwrapper with a symlink to his hijack file but he moved the original to logwrapper.bin
I went into /system/bin renamed logwrapper to logwrapper.bak and then renamed logwrapper.bin to logwrapper.
After that the error went away and it let me patch.
No SBF use required. :)
This worked, thanks.
Google voice search is there on the search widget (first home screen to the right) Just d/l Quadrant and got 1378. I'll run it again after by first reboot. FPS seemed pretty low for most of the test
1436 after reboot :p
I restored my LauncherPro Plus settings from backup and I'm all good now. Sorry for the false alarm. I'm still missing some keys for Touchdown and Docs to Go. It's critical I get this resolved.
Still no charging LED BTW.
Osnap, really? Mine's fully updated and paid as well. Really? No weirdness or anything?
None so far.
One thing that's STILL not fixed is the ridiculously LOW volume level for the "Timer". It still is "7" as the highest and the sound level is still WAY TOO LOW. People with kids that need time-outs should be able to sympathize with me. :)
None so far.
How about the overall volume with the speaker phone etc. ?
As Cory said - I think it may be louder - could just be a placebo effect though. :)
I'll let you know in a few days as to whether I've continued to miss calls. :)
I grabbed the update but haven't loaded it yet. Droidlife says this isn't likely the final version and going back to 2.1 may not be so easy. I think I'll hold off just a bit.
This worked! Thanks man!!
Is the Market Down for anyone else? I've not been able to get on since upgrading to 2.2 and I'm wondering if it has anything to do with the Market being unavailable.
nope market works fine for me. was even able to get the new voice serach options which are pretty sweet.
Cory...is Touchdown expired now since the patch is supposed to fix the problems with corporate sync?
bank bws
