I normally buy everything, but will pass on this. If it had the ability to respond to text and to misses calls it would be on my wrist right now.
If you need to read emails on the watch you can setup the email app that comes with the Note and it will allow you to read at least a part of them. You can set it up for Gmail as well. It's not ideal but it does give you more info on the watch and I think it's a good indicator that it is technically possible and hopefully the Gmail app will get an update to allow the same thing.
Only store that has them within a 50 mile radius.
You can decline a call with the pre-selected text messages. I did this yesterday.
Can you tell me how you set this up..
Sent from my Amazing Note 3
It's actually already set up. Just decline an incoming call and you'll be presented with the preselected options to respond via text.
I haven't figured out how to change them yet though?
This is a great idea. I went into the settings and turned off only the option to sync Gmail from my primary Google account, but left everything else on (Calendar, Keep, Chrome, data backup etc.).
I then set up the Gmail account to push using Samsung's native email app. Now my Gmail email is pushed to the Gear.
Thanks!
It would be nice to have the option of replying to a text message at least with a "form" message such as, I'll call you later, Can't talk at Work, etc.I have not declined a call from the watch yet, I'll experiment and see if the text decline is an option. I have to also say, while I think the screen is awesome on the gear it would be next to impossible to type out a text on the thing and not sure why anyone would even want to try.
Thanks!
I did the same as you DAS last night and set up my gmail and hotmail accounts to push through the Samsung email app and will test today to see if notifications come to the Gear and how much of the message I am able to read. Thanks for the idea.
Ian B
1- Went to Stock email app(looks like a white envelope with @ symbol in middle.Can you explain how to do this I would love the steps.....
Thanks
Sent from my SM-N900P using Tapatalk 4
What about aol
2- Created hotmail.com account(dont go through manual process of setting account) and selected "push" for sending emails to Note/Gear. Put your email address and password, follow the steps and you are done.
3- Create gmail.com account and do the same as step #2.
4- Go in your Note to Settings-General-Accounts. Select the Google account and hit enter, Uncheck box by Sync Gmail.
This is how I have it set up and Hotmail as well as gmail emails are coming into the Note and Gear.
Someone correct me if I am wrong.
Ian B
