Galaxy Note 3 Battery Review
How do you do that?
Nothing too special. I enable power saving mode, keep the display brightness pretty low (probably at a setting of 10 out of 100), and only autosync necessary apps. I find the display on the Note 3 really, really bright compared to my old S3, so the 10/100 setting is plenty bright. Also, a lot of the 8 hours of screen time was spent browsing or doodling in the sketchbook app (where there's no real data/video/music). I'd say only ~1 hours of the screen usage was for videos (like netflix, youtube, etc.).
Adding screenshots:
Has anyone tested battery life with gaming? Most of these battery test shows nobody ever plays games on the Note 3. Just play a game max graphics at 50% brightness for 30 to 60 minutes, then post how much battery % you used and we'll be able to take out our calculators and do the math on how many hours of gaming this can do
Adding screenshots:
http://i.imgur.com/oNizXByl.png
http://i.imgur.com/EbbVNi4l.png
Holy ****. Do you turn on airplane mode and use at the lowest brightness?
LOL, no. No airplane mode whatsoever, although I should mention that most of the data usage was on WIFI (not sure if that's better/worse compared to 4G LTE battery consumption wise). My screen brightness was dialed down pretty low (probably 10/100), but even at this setting, the screen was plenty bright. I find the screen on my Note 3 to be crazy bright, compared to my old S3. Almost overkill, unless you're outside in bright sunlight...
Damn, I'm jelly XD I can get 5 or so hours on my S4 over 10-15 hours depending on my day. I want to try and get 6+ hours by using airplane mode.
Time to upgrade your S4 and get a Note 3 and you can get this battery life too :)
Had my s4 for 6 months and upgraded to my note 3 and not looking back love every minute of it.
Sent from my SM-N900P using AC Forums mobile app
This is my first full day and nothing to be excited about. At all. :( brightness probably at 15%
Sent from my SM-N900V using Tapatalk
Just thought about something. I am using the Samsung default orange background for both lockscreen and home screen. Does that contribute to eating of battery. I wonder if a dark background would change that.
Yes, using dark backgrounds (Color black more-so than others) will decrease battery consumption :D
The battery life on my Note3 is much, much worse than the Note2. I'm not sure what to do?
Reduce screen brightness. Keep it on a dock. Carry a spare battery. Or return the phone.
I'm sticking with suggestions 2 and 3, but battery life seems to be improving a bit these past few days.
sent from my Note 3
Mine seems to have improved with the new maps update. I haven't changed any settings but the battery seems to have settled down a bit and is not draining as quickly. Fingers crossed. As I mentioned before, before all the apps downloaded upon activation, the battery was talking forever to drop from 100% > 75%. We'll see....
Sent via The Big, Bad, Beautiful Note 3
So can we compile the data and see how much impact does screen brightness have on the battery life?
10%--> 8 hrs
50%--> 6 hrs?
100%-->4 hrs?
@T-Mobile GN3
cbbella
