Galaxy Note 8 Tempered glass screen protector
These last few Amazon ones look promising but why do they all.have black edge? :( I would prefer it all clear.
After a few Amazon fails...I went to my local Fry's and bought this one for $ 19.99. I have no loss of screen sensitivity and Spen works great.
Cellio 3D Curved Glass Screen Protector for Samsung Galaxy Note8
How is this after some use? And what case are you using with it? Thanks.
That's the worse reason I was hoping not to hear :( That means the choice is between soft films or tampered glass. For me the only problem with the glass is that it's so visible on the device :/
Wow.. The 6 reviews before were all 5 star.. Now you are right the latest reviews are not good... Before I trusted Amazon reviews... Going to cancel my order.
I just bought this one, Full Adhesive...
https://www.amazon.com/gp/product/B...ag=hawk-future-20&ascsubtag=UUacUvbUpU6011938
I'll let you know next week when I get it. Cheaper than the other "Full Adhesive" ones posted above...
Well guys, unfortunately this one did not work out. It seems to be great quality. Packaging was good and the install tool also seemed great. When I put the screen down the center fully stuck with no bubbles. Then I removed the installation device and the left side set down perfectly. Unfortunately, the right side along the entire edge would not stick! I worked it for a good half hour before I gave up...I think they designed it a tad bit too wide. Hopefully I can get a refund and try another...
Yeah I think they have a defect in there every review I've seen said the right side didn't stick
Sucks because the left side laid down perfectly, they're sending me another one and if it does the same thing they will refund. She said the next version will be better but who knows how long that will take....
Anyway just wanted to share especially to first time users of curved tempered glass, the main portion you need to press down firmly is on the sides. Not in the middle. As there is NO adhesive in the middle.
Thought I will just share this.
https://youtu.be/DA6AjHla5ss
The price is already higher. Did you end up getting this?
Yes. With Amazon I know if the protector is defective I will be able to return it. If it is I will wait until the Bodyguardz new es protector is released. Maybe by then the Whitestone will come down in price. I still have film protectors to use in the mean time.
What should Bodyguardz be released?
iwansandi19
