Galaxy Note 8 Tempered glass screen protector
Just installed the Zagg glass screen protector. So far I like it and it was an easy install. Let's hope it stays on I could not get one to stay for the s7edge
Yup. I've had the Zagg Curve on my Note8 for a couple of days and I have no issues at all.
The glue doesn't completely harden. It becomes so tacky that you can't tell the difference. I installed one on my S8+ and put a case on it that lifted up an edge. Took the case off and it settled back down on the phone by itself. It looks like it did on the 1st of installation today, several months later.
U Droid removes 1 in this video ...
https://youtu.be/-fbZ9HtcYOA?t=21m50s
I was impressed by this. May have changed my mind on tempered glass protectors.
Scratch that, I think it's like 80$. The S8 one is 80 so I'm assuming this one is as well. I think the 18$ one is just your normal tempered glass with the edges...
i had the zagg screen protector installed, 2x at Verizon and each one has terrible sensitivity on the corners. I'm getting alot of missed screen touches.
Wow. The screen sensitivity on mine is the best that I have ever seen on any phone. You can not tell that the screen protector is even installed.
Did the Verizon guy use the red application guide when applying the Zagg? Just asking because I've had Zaggs on prior phones and there have been some sensitvity issues, but there are none on the Note8 for me.
I've got the Zagg Invisible Shield on my Note 5, albeit flat screen. After five months, perfect. Best ballistic protector to date. Watching this thread closely. Have the Note 8 in the same Ultra Thin Spigen case. Love this case! However NO screen protector as yet. Would like to see more reviews on the Zagg Curve Glass.
I ordered this from www.powerpeakproducts.com which is the link he gives to buy it, & got scammed... Beware of this company as the seem to be a sham. They charged me, but never shipped it. The also won't reply to emails or answer thier phones.... :-(
I ordered this from www.powerpeakproducts.com which is the link he gives to buy it, & got scammed... Beware of this company as the seem to be a sham. They charged me, but never shipped it. The also won't reply to emails or answer their phones.... :-(
Jimmy Is Promo just uploaded another video but yesterday responding to the shipping problems around the Base TGSP.
I'm personally not as enamoured with it as he is. I get only halfway decent response from the screen, but it's really clean with the Caseology cases I have. Waiting for my UV light to get delivered so I can set up my DIY Whitestone.
I have the zagg glass, so does my daughter. We did hers first yesterday. I wanted to see if it messed with screen sensitivity. It works great! Hers did have a lot of fingerprints after work, but she must have had greasy fingers. I used mine all day yesterday and this morning and only had few, they wiped off really easy. No problems so far, it looks really nice. I did pen testing as well with it yesterday....
My mom has the zagg glass on hers. It looks pretty good. I may have to end up getting it on mine. I currently have the Spigen neoflex. It's good, but I think glass may be the way to go.
I just received and installed the Zagg Invisible Shield Glass Curve. Yes, it is expensive but it is different and I think it is really good!
1) The installation is idi0t-proof. They have a new system that makes applying this protector really easy and perfectly placed.
2) I have not found any screen sensitivity issues whatsoever (so far).
3) I have a Samsung Alcantara case and there does not seem to be any issues with the case compatibility.
I will update this post if I find any issues, but so far this screen protector looks and feels great. (I have used Zagg Glass before on previous devices and some worked fine and some had screen sensitivity issues.) This one for the Note8 is very different and I am hopeful that it performs as well as my first reaction!!
Can younuse a case over it?
I have currently have the Spigen Ultra Hybrid case. Is there any tempered glass screen protector that will work with this case?
I decided to go ahead and give it a go after the kids went to bed so I could concentrate. It went smooth I made sure to level out the installation tray with a small level, just needed one credit card to make it perfect. A tiny bit of glue came out of one edge, you can see it in one of the pictures. I was able to use one of the included alcohol wipes to get it off and now it’s perfect. It really is a great protector and worth the money. I’m going to let it sit tonight and use it some tomorrow, I have a Otter Box defender case but I’m not even going to try it in that case. I’ve got a Samsung rugged kickstand case and a UAG Monarch coming that should work with the protector.
Would appreciate hearing how it fits with the Monarch. I've read elsewhere that they're incompatible.
jeffnachatilo
