Galaxy S3: Photos are always being rotated! Why!
If I take a photo in landscape mode then it is completely upside down!! If I take it in regular orientation then it is only 90 degress off.
I believe this is a conversion process from Android to Windows, and most likely needs an app written to correct the translation.
I had a same problem but solved it. U should go to display setting+Horizontal calibration+then place your phone on a level surface and tap calibrate then your image never rotate anymore :-)
Say what? What the heck phone are you using?
AC App on SGS3
My S II Android won't rotate to 'portrait' with the home key at the bottom....very frustrating as upside down portrait, and landscape works.:(
Re: Photos are always being rotated! Why!
Doesn't work ...only works in three phone positions....upside down portrait, landscape (both views). Right side up portrait won't take or set as a permanent position.
Doesn't work...I calibrated both 'horizontal' and 'gyroscope' calibrations and I still cannot get a portrait shot with the home key at the bottom. HELP...SO GDAM FRUSTRATING!!!! SAMSUNG HELP DESK WHERE ARE YOUUUUUUUUUUU.
Why are so many people who don't understand the issue that is happening making negative comments about not knowing how to hold a freakin' phone for taking photos. It has NOTHING to do with that. I used an LG phone for 3 years and it always had the orientation of the photo noted and displayed properly when transferred to ANY PC program that displays or stores photo.
With my Samsung Galaxy Grand Prime, which has really good cameras, I am experiencing this as well.
So, those with knowledge - IS THERE A FIX FOR THIS (that does not involving having to rotate photos later). ?
It's a simple question - maybe in all the responses here there is an answer already, but I certainly can't find it. Instead, I'm finding all kinds of assumptive comments from people not even experiencing the issue here.
I'm bradinca at gmail - drop me a line if there's an easy fix for this please. You know, a setting on the phone somewhere. I simply want to take a photo with my phone in vertical (portrait mode) like MOST people take photos and selfies with their phone, and have it be in proper orientation for programs (on a PC) that do not read EXIF data and orientate the photo different than the source photo would suggest. MOST OF my photos on a recent vacation require a 90 degree RIGHT rotation to correct for PC viewing. Some are okay though - and perhaps this happened when I put the phone in portrait, turned to landscape, THEN turned back to portrait before taking the photo as some people has indicated may have it orientating right --- this, of course, is not an acceptable thing to do on most or every photo take, ha !
Thanks if you know how to fix this and can let me know ....
bradinca at gmail .... Appreciated !
RangelS25
